DBR Posted August 16, 2006 Share Posted August 16, 2006 has anybody got a diagram of how to remove the side vent things in fornt of the rear wheels.......... ( incase you hadnt noticed im quite a techy' ) Ive got the supra manual of CJ but cant seem to find anything in there about removing them. thanks Quote Link to comment Share on other sites More sharing options...
Angarak Posted August 16, 2006 Share Posted August 16, 2006 I think the bolts holding it in are either 10mm or 12mm. You may have to take your wheel off to gain enough access to the bolts. EDIT: Oops, the above was for the side-vent-thingy that is fixed to the inside of the arch Having just re-read your question I think your asking about the trim above the sideskirt just before the rear wheel. There are 2 plastic lugs at the rear of this trim (nearest the wheel) that you need to remove (see pic below). There are 2 bolts underneath that go into the sill that need removing (I think they are 12mm). Once you have them out there are several 'push' clips that will give with a gentle pull. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted August 16, 2006 Share Posted August 16, 2006 3 screws underneath, two push pins in the arch, then it is held on with "poppers", a gentle tug is the way here Quote Link to comment Share on other sites More sharing options...
Pete Posted August 16, 2006 Share Posted August 16, 2006 a gentle tug is the way here This solves most problems in life...or at least makes them more bareable. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted August 16, 2006 Share Posted August 16, 2006 indeed;) Quote Link to comment Share on other sites More sharing options...
DBR Posted August 16, 2006 Author Share Posted August 16, 2006 cheers fella's ....... ill give it a go tonight......if i break somthing im blaming you Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted August 16, 2006 Share Posted August 16, 2006 Awsome i've just bought some skirts and was going to ask the same thing! Quote Link to comment Share on other sites More sharing options...
DBR Posted August 30, 2006 Author Share Posted August 30, 2006 err this may sound stupid.... but.... i cant get the little plastic poppers out, they feel like there gonna brake if i force them anymore.............. any suggestions:confused: Quote Link to comment Share on other sites More sharing options...
Ian W Posted August 30, 2006 Share Posted August 30, 2006 err this may sound stupid.... but.... i cant get the little plastic poppers out, they feel like there gonna brake if i force them anymore.............. any suggestions:confused: break them and get some new ones? Quote Link to comment Share on other sites More sharing options...
