toyotasuprauk Posted March 6, 2004 Share Posted March 6, 2004 Is there a difference between an ignition coil and an ignition lead? What does the Non turbo Supra use? For some reason one of my leads the first one (ie closest to the front of the car) seems to be in much worse condition than the others and some of the rubber that holds it firmly in place has crumbled away. It still seems to work fine but if its possible I wouldn't mind replacing it just to be on the safe side. I don't know why one should look so much worse than the other five (which all look like new) but is it possible to buy just one from Toyota, or are there any alternatives companies I should consider? Thanks Adrian Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted March 7, 2004 Share Posted March 7, 2004 Change the whole lot, then you know where you're starting from. Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted March 7, 2004 Author Share Posted March 7, 2004 Probably a good idea just in case. Does anyone know if companies like NGK sell the leads or is it better to stick with Toyota? Quote Link to comment Share on other sites More sharing options...
