Max pressure the NA head can hold?
Daston
Hi guys
Would normaly be asking the ClubNA-T guys this but their site seems to be gone.
Whats the max boost that the NA engine can hold on a stage 1 kit? Am I right in thinking its 8psi (being safe). Reason why I ask is cause I have a 5.8psi spring in my waste gate and was wondering if its worth putting a boost controler in to raise the boost to 8psi (or what ever the max safe figure is).
Cheers
  • Replies 52
Posted Images
I would not run more than 7psi, stick with the 5.8 spring and run that boost dont forget your fueling is so important buy a aem wideband to keep a check on things, trust me it is worth doing the head gasket at this stage as you will only want to up the boost very shortly after your install
Not familiar with it, but make sure before you buy that someone has experience in setting one up as you may as well just go for a second hand safc, good luck with it and keep us informed, btw I would do a test fit of that manifold and turbo just to make sure about clearance
The neo is the same as the S-AFC II but with some bell and whistles like full colour display and a few extra monitoring tools.
When I take the Manifold off do I need to take out the down pipe as well or can I get away with not having to jack the car up? It's just I tried that approach and couldn't get the car high enough to crawl under.
ok the 8 manifold bolts are off and the 2 o2 sensors are out now whats the easy way of getting the mainfold away from the down pipe is it a case of jacking up the front quater and squeezing under? or is there a cunning way?
If you want to push your NA-T performance nearer the limit (maintaining some margin of safety) then you really need something that will allow you to setup up the fuelling spot on and adjust your ignition timing. An EManage Ultimate (or even a Blue if you're not going stupid with injector size) would be perfect.
I would also be ducting the front mount intercooler, heat shield on your intake, fitting a water injection system, consider a thermostat controlled oil cooler (to help remove heat from the combustion chamber and underside of the pistons as effectively as possible), make sure the coolant system is perfect.
