Jezz Posted October 17, 2006 Share Posted October 17, 2006 Jezzy: Dont spose you have an Ignitor unit in stock do you?? Yes me old fruit. I'll test it on my car tomorrow and if it doesnt work i can sell it you. If it works, i'll keep it. Ok, switch that. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 17, 2006 Share Posted October 17, 2006 Jezzy, I hope at some point during this whole weekend you've spent fixing your car, that you devoted a little time into getting some bubble wrap for my TRD spoiler your sending me? Quote Link to comment Share on other sites More sharing options...
Jezz Posted October 17, 2006 Share Posted October 17, 2006 Jezzy, I hope at some point during this whole weekend you've spent fixing your car, that you devoted a little time into getting some bubble wrap for my TRD spoiler your sending me? What spoiler? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 17, 2006 Share Posted October 17, 2006 LOL, pm recieved, cheers. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 17, 2006 Author Share Posted October 17, 2006 Yes me old fruit. I'll test it on my car tomorrow and if it doesnt work i can sell it you. If it works, i'll keep it. Ok, switch that. Cheers mate, let me know ASAP cos if its in working order and a reasonable price ill take it. Quote Link to comment Share on other sites More sharing options...
Lez Posted October 18, 2006 Share Posted October 18, 2006 Are you sure about the direction of the IAC's seal washer? The exploded view in mkiv.com shows (imo) the flat side towards the iac valve/stepper motor and the bevel towards the check valve. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 18, 2006 Author Share Posted October 18, 2006 Are you sure about the direction of the IAC's seal washer? The exploded view in mkiv.com shows (imo) the flat side towards the iac valve/stepper motor and the bevel towards the check valve. Hmm good spot. That is the why i have put mine in. Really confused now. Might try it the other way round just to see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
toyo rob Posted October 18, 2006 Share Posted October 18, 2006 its ambiguous isn't it. all i can say is that i too had it with the concave side on the valve side, and when i changed it my problems have been cured. Rob Quote Link to comment Share on other sites More sharing options...
Lez Posted October 18, 2006 Share Posted October 18, 2006 its ambiguous isn't it. all i can say is that i too had it with the concave side on the valve side, and when i changed it my problems have been cured. Rob Which valve Rob, the 'check valve' (inside the inlet manifold) or the IAC valve (attached to the manifold)? Quote Link to comment Share on other sites More sharing options...
toyo rob Posted October 19, 2006 Share Posted October 19, 2006 right, i've changed the picture. see below this is my current configuration.... as i interpreted an answer from Ian C, Rob Quote Link to comment Share on other sites More sharing options...
Lez Posted October 20, 2006 Share Posted October 20, 2006 Rob I still think your wrong, no I know your wrong. Have a look at the middle pic on the 4th page seal direction But its got me thinking, have I got the check valve the right way round. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 20, 2006 Author Share Posted October 20, 2006 Just tried mine both ways and still got the miss so that obviously aint my prob. Got a new Ignitor and O2 sensor on the way so will try them when they arrive. Quote Link to comment Share on other sites More sharing options...
Gamer Posted October 20, 2006 Share Posted October 20, 2006 Just tried mine both ways and still got the miss so that obviously aint my prob. Got a new Ignitor and O2 sensor on the way so will try them when they arrive. My money is still on the O2 sensor being the culprit. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 20, 2006 Author Share Posted October 20, 2006 My money is still on the O2 sensor being the culprit. Im hoping you are right. Might save me a fortune. Quote Link to comment Share on other sites More sharing options...
Jezz Posted October 20, 2006 Share Posted October 20, 2006 My money is still on the O2 sensor being the culprit. I'll see your money, and i'll raise you some more money? Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 21, 2006 Author Share Posted October 21, 2006 Well the O2 sensor and Ignitor arrived this morning and still got the missfire. Tempted to swap the AIC back around and try it the other way with the new bits installed. Failing that im all out of ideas and will have to leave it to the garage on wednesday, just hope they can find it quickly so the labour charge doesnt creep up. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 24, 2006 Author Share Posted October 24, 2006 Just had a good friend who is a mechanic round before it goes to the garage tomorrow. Bascially want to check everything we could before it goes in so that Labour costs will be to a minimum trying to diagnose. Did a compression test and all 9bar (thank god), tested all the sparks and No3 had a weak blue spark, regardless of which coil pack we used, changed the plug and had the same outcome. So its neither the plug or coil pack. Hes fairly confident this is what is causing the problem but couldnt narrow it down any further than that. At least ive got something to tell the guys tomorrow and just very relieved that there's unlikely to be something major mechanically wrong. Quote Link to comment Share on other sites More sharing options...
bondango Posted October 24, 2006 Share Posted October 24, 2006 Gaz did you try a new igniter and also check the igniter connection and loom for any damage? maybe worth checking the emanage ignition harness wiring connections too. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 24, 2006 Author Share Posted October 24, 2006 Gaz did you try a new igniter and also check the igniter connection and loom for any damage? maybe worth checking the emanage ignition harness wiring connections too. Changed the ignitor for another second hand one (was working when came off car), made no difference. The connections to it looked ok but not tested them. Not got an emanage so no probs there Quote Link to comment Share on other sites More sharing options...
bondango Posted October 24, 2006 Share Posted October 24, 2006 Changed the ignitor for another second hand one (was working when came off car), made no difference. The connections to it looked ok but not tested them. Not got an emanage so no probs there Sorry just noticed it was on the shopping list Weak spark sounds suspiciously like a bad coil pack earth, but id look at all the following.. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 24, 2006 Author Share Posted October 24, 2006 Sorry just noticed it was on the shopping list Weak spark sounds suspiciously like a bad coil pack earth, but id look at all the following.. We did think whether it was an earthing issue but thought that if it was it would be more of a yellowish flame not a blue one. Could be wrong though. Youre gonna need to explain that diagram mate, im far from a tech head. Quote Link to comment Share on other sites More sharing options...
bondango Posted October 24, 2006 Share Posted October 24, 2006 Gis 10 minutes and il throw up a better explanation :-) Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 24, 2006 Author Share Posted October 24, 2006 Gis 10 minutes and il throw up a better explanation :-) Nice one mate. Quote Link to comment Share on other sites More sharing options...
bondango Posted October 24, 2006 Share Posted October 24, 2006 Sorry i should have said power source!!! after me bed time lol The control line between the Ignitier and the coil pulls down by earthing, other side is the power not earth as i said Quote Link to comment Share on other sites More sharing options...
bondango Posted October 24, 2006 Share Posted October 24, 2006 Ok try this one.. marty Quote Link to comment Share on other sites More sharing options...
