Uprated Autobox and Torque Converter
Gruggs
The BL box is great, and coupled with a 3200 or a 3800 TC it will fly. Just dont forget about the cooling, its often overlooked.
We should be able to supply these box's and TC's off the shelf as of next week and will come with a FULL boostlogic warentee. Exchange units required. Outright buy available
Heat is the main killer apart from running too much power through it or just abusing it in general.
The TC and other moving parts within the box create extra heat and if not kept in check can and will destroy the box. Firstly by cooking the fluid and that will then damage other parts like the clutch packs or even the TC. This is assuming that you are indeed running more then stock power levels. You could probably get away with using the stock cooling in that case but who would be getting a built gearbox to run on stockers anyway.
More power = more heat
