exhaust gas bypass valve (vsv)
D8MOA
on my car one of the pipes has broken so at the moment i have buypassed the vsv,
what should/will happen when this is done? missfire? boost problem?
If you've bypassed the EGBV VSV then pressure from the intake will continually leak back into the the non-pressurised side of the induction system and the actuator, and therefore valve, will never open. This means turbo 2 won't be prespooled and will go from seeing no gas flow to full flow every time it comes online (effectively being "shocked" into use). This isn't particularily good for it so you might be better running TTC (where the EGBV is irrelevant) until you get a new one.
i was just about to say that :D
TTC?? so just disconnect it? bloody good decription buy the way.thanks
TTC is true twin conversion or "parallel". Leave the EGBV VSV bypassed as you have done and also bypass the EGCV and IACV VSVs. See here: http://www.mkiv.com/techarticles/ttc/ttc.htm. Both turbos will come online at the same time (although at much higher rpm) leaving the EGBV redundant.
