Baz786 Posted August 12, 2006 Share Posted August 12, 2006 Would skyline brembos fit on TT supra? any advice is appreciated:d Link to comment Share on other sites More sharing options...
TLicense Posted August 12, 2006 Share Posted August 12, 2006 The calipers I believe are all the same. It's the mounting bracket that would probably not fit suprisingly Link to comment Share on other sites More sharing options...
Baz786 Posted August 12, 2006 Author Share Posted August 12, 2006 I need to know for def, getting a good deal on the set... Link to comment Share on other sites More sharing options...
Alex Posted August 12, 2006 Share Posted August 12, 2006 The calipers I believe are all the same. It's the mounting bracket that would probably not fit suprisingly If you know of a fabricator that can make you a mounting bracket then there's no reason why not. Chris Wilson makes his own. But they are not BETTER than the standard UK/US spec brakes. Link to comment Share on other sites More sharing options...
Baz786 Posted August 12, 2006 Author Share Posted August 12, 2006 Are the standard uk ones better than Brembos???? Link to comment Share on other sites More sharing options...
Alex Posted August 12, 2006 Share Posted August 12, 2006 Yep....but they are probably heavier. Link to comment Share on other sites More sharing options...
paul mac Posted August 12, 2006 Share Posted August 12, 2006 you can get any calipers to fit as long as the mounting holes dont overlap (a mounting plate is tricky) and the radius of the disk that they came off is within about 10mm of what you want to put them on, however you have to have a smidge of engineering know how and be able to produce a drawing that a machinist can read (back of a fag packet wont do), i made these for nissan 300zx calipers as i was pissed off with the constantly sticking J-spec rears and could'nt justify £450 for UK specs, expect to pay about £100 for them to be made Link to comment Share on other sites More sharing options...
