Advanced notice of many TT parts to be sold
Terminator
Assuming that no one else has asked fo rthem. And I WILL NOT be seelign these parts back to the forum members!!!!
Tom’s Racing panel filter direct stock replacement, increased flow and washable. Supplied cleaned and oiled
Working starter
Stock TB with TRAC remval kit fitted
HKS Track removal kit new.
HKS Throttle body IC elbow pipe, polished with flange for HKS SSQV
Stock JDM rail and 440 injectors
Rare Trust 3 row SMIC Pressure tested to 40 psi. One of the best SMIC available.
Polished SMIC pipework
Stock Auto radiator, very clean, Toyota Red for Life changed twice in 30000 miles.
Chris Wilson turbo back first cat replacement pipe with restrictor ring
HKS second cat replacement pipe.
Stock water pump 45K miles
Two brand new unused walbro fuel pumps
Built bottom end with pans, new pan two. High spec to follow
HKS 1.8 mm head gasket used once on on engine build, never seen any compression head removed to fit thicker gasket
Stock JDM long block with pans. And oil pump 65k miles
Stock JDM long block with pans, oil pump, crank pulley cam pulleys and belt and front covers 45K miles
Set of stock pans
Stock Auto ECU taken from 15K car.
Mint stock cam covers
Stock rods and pistons 60k miles
Job lot price please phil!
Cheers
As said in the first post these bits will be available in a month or two. I just posted to help anyone with plans to purchase bits in the near future. As bits are ready I will post full details.
As has already been pointed out some of these parts were indeed offered on the BBS about a year ago. The delay in my build was unavoidable. However from my point of view, things have turned out much better than I could have hoped, so the wait was worth it
  • 4 weeks later...
