b_have Posted August 10, 2006 Share Posted August 10, 2006 Imported two, but only have one Supra now Great for single turbo/high boost set ups. Designed primarily for drag race applications, this crankcase evacuation system is designed to reduce pressure build-up in the engine crankcase, providing for better piston ring seal, less intake charge contamination, and reduced oil leaks caused by high crankcase pressures, while increasing engine performance. Kit includes a chrome plated Mopar style push-on valve cover breather,breather grommet,a check valve and 3-1/2 inch long, 45° cut/threaded tube, which must be welded into the downpipe.This creates a vacuum and safe dumping of excess c'case pressure. £50 +post. Link to comment Share on other sites More sharing options...
b_have Posted August 10, 2006 Author Share Posted August 10, 2006 Edited with more info. Link to comment Share on other sites More sharing options...
