Matt Harwood Posted February 29, 2004 Share Posted February 29, 2004 It's very unlikely to be the Alarm. We've fitted hundreds of the Ai606 and I've never yet had an immobiliser on one of them go faulty. (there's a first time for everything though). Are you saying that is you connect everything as it should be, but splice a positive directly to the starters soleniod, it will crank but not start, yet if you remove the OE cable, and put a positive on the same terminal, it will start? - Thats very confusing, (and again disregards the alarm as one immobiliser circuit would have nothing to do with the other immobilised circiuts) Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 29, 2004 Author Share Posted February 29, 2004 Matt, That seems to be the sum of it yes. I totally agree with what your saying about the alarm. I'm wondering if the park/neutral switch has more going on in it than meets the eye. Looking at the wiring diagram attached it appears that by splicing wire 6-5 it should make the car think it's in par/neutral and allow the car to start. However on the Service hints on the image attached to the next post, it would seem to suggest that there is more going on with the switch than just a simple "open/close in this situation" direct to the starter. Matt, could you try and put what this diagram is saying into layman's terms as I don't really understand it. Many thanks Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 29, 2004 Author Share Posted February 29, 2004 Heres the servicing hints image Quote Link to comment Share on other sites More sharing options...
TLicense Posted February 29, 2004 Author Share Posted February 29, 2004 OK I think I'm starting to get somewhere with these electrical diagrams. From the look at it, pins 5 and 6 are the positive and ground. I then looking at the attached diagram here, need to connect either 4 and 7 or 4 and 10. This would effectively be "fooling" everything else into thinking it's in neutral or park. Is this right or am I getting the whole positive/ground bit wrong? Quote Link to comment Share on other sites More sharing options...
TLicense Posted March 1, 2004 Author Share Posted March 1, 2004 OK I've sorted it. Basically, the park/neutral switch had moved to being in reverse or drive. I've managed to by-pass it by connecting pins 6 and 5. (I've now removed said switch completely) I've also learnt how to read electrical drawings. Not as hard-core as they look really. Cheers chaps for all your help. Quote Link to comment Share on other sites More sharing options...
jagman Posted March 1, 2004 Share Posted March 1, 2004 well done Tony aka "sparks" Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 1, 2004 Share Posted March 1, 2004 Well done Tony... I would have answered you, but I couldn't get on the BBS last night... Quote Link to comment Share on other sites More sharing options...
TLicense Posted March 1, 2004 Author Share Posted March 1, 2004 No worries Matt, After I sent those posts, neither could I, so I wouldn't have been able to read the respone anyway Is it still OK if I pop down to see you this Saturday? Thanks for all your help Tony Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 1, 2004 Share Posted March 1, 2004 Yeah, shouldn't be a problem... Afternoon is always better on a Saturday... Quote Link to comment Share on other sites More sharing options...
