Registered Nutter Posted October 15, 2001 Share Posted October 15, 2001 Having taken the general advice of not driving my car till the turbos have been sorted out. was showing the car to a friend the other day incase they had any suggestions as to my current problem when he noticed that black smoke was coming out the exhaust at 4000 rpm and above just hoping that this is part of my exsisting turbo problem and not anything else aswell. please bear in mind my tech knowledge is not that great. The car is going to tdi on thursday to be sorted out but as you guys have said before i dont want to give them a blank cheque. cheers for any help Quote Link to comment Share on other sites More sharing options...
AJI Posted October 15, 2001 Share Posted October 15, 2001 Dude, If you have a turbo problem then its not a good idea to rev your engine up to 4000rpm, I've no idea of what your turbo problem is but if black smoke is coming out of your exhaust is definately a bad sign. If there is a oil supply problem within your engine then black smoke usually indicates that engine parts are being worn away, but I'm only guessing at your problem. Can be very expensive if you do it too often. AJI Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 15, 2001 Share Posted October 15, 2001 Is this 4000 rpm at wide-open throttle (WOT) or at 4000 rpm cruise? Yours, J Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted October 15, 2001 Author Share Posted October 15, 2001 it happened when i put my foot down only for a few seconds have not been driving the car at all since problems started so it had only been running for 30 seconds when it happens. but do have to drive it the hundred odd miles to tdi. also TDI seem to think it is just a sign of the second turbo being blown. Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 15, 2001 Share Posted October 15, 2001 Tell me please, what is your current turbo problem? Generally, at maximum boost, at wide-open throttle, someone following will see darker smoke coming from the exhaust. In a mild case, this is ordinary mixture enrichment that occurs at WOT with a high-power turbo car. In a not so mild case it could be a result of a mega mixture enrichment due to someone having fitted some additional fuel injection device that is not set up properly. You say you did this after 30 seconds of running? in which case I am not surprised... the engine would have nowhere near completed its warm-up cycle, (enrichment phase). But what is wrong with your car, exactly? Yours, J Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted October 15, 2001 Author Share Posted October 15, 2001 turbo problem copied from a previous post Put my foot down the other day and everything was as normal until I shifted into 4th when I saw a fair sized cloud of smoke come out the back and no weird noises were made but obviously I pulled over rather concerned about my new car everything seemed fine so drove off again but no 2nd turbo. The car doesn't make any disturbing noises or show any signs of having anything wrong with it apart from the lack of power. having spoken to TDI they said this is a common problem with the ceramic blades and they can disintegrate if pushed hard to much and suggested that I give them the car so they can send both turbos off to be rebuilt and have steel blades put in them. Does this seem like the correct solution? Is it ok to drive the car in the meantime? (bearing in mind its my only car.) Is it likely to be my fault by driving the car to hard? Also car only has 14k miles on the clock and all this happened the day after I had the rltc fitted and a super dragger exhaust & blitz bov & air induction. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted October 15, 2001 Share Posted October 15, 2001 Oiiiiiii Nutter!!!!!! (sorry just had too) Have you checked all those induction hoses yet ?? Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted October 15, 2001 Author Share Posted October 15, 2001 yeah had the best look i could then had a local guy had a look at it too everything seems to be fine hose wise Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted October 15, 2001 Author Share Posted October 15, 2001 was wondering if the smoke could be caused by oil in the exhaust from when the turbo blew? Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 15, 2001 Share Posted October 15, 2001 Yes, now I remember this thread. I replied that you should have the problem diagnosed *first* before deciding on the best course of action. Your car has only 14k miles on the clock, in which case turbo failure would be mighty *unusual* to say the least. You say all this happened the day after you had the RLTC fitted, together with a Super Drager Exhaust and a Blitz BOV and induction kit. Who fitted the above components, may I ask? Yours, J Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted October 16, 2001 Author Share Posted October 16, 2001 racelogic fitted the traction control & bov. local place fitted the exhaust & air induction. also so i know when i have had it fixed how often to you guys drive your cars hard. i cant help but worry that the problems are caused by me pushing the car to hard Quote Link to comment Share on other sites More sharing options...
matt Posted October 16, 2001 Share Posted October 16, 2001 Quote: from Registered Nutter on 9:10 am on Oct. 16, 2001[br]. also so i know when i have had it fixed how often to you guys drive your cars hard At every opportunity ........................... doesn't everyone??? :biggrin: The Soops very reliable ......... sounds like a case of "shit happens" ,to me Quote Link to comment Share on other sites More sharing options...
