Carl Posted August 9, 2006 Share Posted August 9, 2006 A bit of an odd one. I have bought a new battery to replace my old J-Spec one. The New battery has the larger diameter battery terminals so I will have to replace the end bits on the leads to fit to them. I wondered if anyone has a set of std UK ones I could fit. Carl Link to comment Share on other sites More sharing options...
Rob Davey Posted August 9, 2006 Share Posted August 9, 2006 A bit of an odd one. I have bought a new battery to replace my old J-Spec one. The New battery has the larger diameter battery terminals so I will have to replace the end bits on the leads to fit to them. I wondered if anyone has a set of std UK ones I could fit. Carl Are you sure the battery is in the right way around? The positive and negative terminals are different sizes. Link to comment Share on other sites More sharing options...
Carl Posted August 9, 2006 Author Share Posted August 9, 2006 The J-spec was something like 12mm & 13.5mm. The UK spec battery is around 15mm & 16.5, something in that region. Hence why my leads wont fit over them due to considerably different terminal diameters. Carl Link to comment Share on other sites More sharing options...
Rob Davey Posted August 9, 2006 Share Posted August 9, 2006 The J-spec was something like 12mm & 13.5mm. The UK spec battery is around 15mm & 16.5, something in that region. Hence why my leads wont fit over them due to considerably different terminal diameters. Carl never knew that! Link to comment Share on other sites More sharing options...
