1st prob
Missile
My clutch pedal has been from time to time getting stuck down, Was unsure why this was, But after two weeks of driving plus driving to pod, Its finally got stuck down to the point where its not working. So its off the road:(
Ive tracked to prob down to having no where near enough clutch fuid in the pot.
So its filled with air.
What im after is somone to tell me the best way to bleed it.
The way im doing it is not working :sos: :sos: :sos: :slapped: :hunter: :hang: :badmood:
You *do* know how to bleed, right?
If you have no bleed pump (or those one-way valve kits) then you need someone else to help you from the cabin.
It's no big deal, even if you filled it with air accidentaly, there is no harm done - just fill the reservoir and try again. Never let the reservoir run empty.
Yip, Im all good for bleeding, Well i was doing it like i would for brakes,
So could be doing it wrong.
Dad in the car pushing down the clutch, Me underneath opening and closing the bleed nipple, And a mate looking at the fluid level.
I bought a workshop manuel from e-bay, Its got everything bar how to bleed it.
Someone told me to undo the bleed nipple, Leave it for 5 mins then do it back up, Cant see how that would work . . .
Grim, Never thought it would end up off the road this quick:angry:
I will get back under it tonight and try again.
