My first Supra
rovervi
i also dont understand the 'manu' button is it semi manual or something
you need to have a little search around me thinks and then go out and enjoy the new toy and its features.........
..........very nice sup, well done on getting the facelift worth the little extra IMO.........does it have the large brakes hiding under those 17's?
Thanks, i think the extra is worth it too i think the brakes are the bigger ones but how can i check for sure
if there is very little room between the calipers and the wheel (both rim and spoke), like literally a mm or two then you have the large brakes.......the smaller ones will be quite a distance from the spokes (can probably get a finger between the spoke and caliper...............
Post a photo.. someone will tell you.. they should look like these though I would really be surprised if it did have them
i wouldn't loads of the facelift NA's had them............(sounds a bit know it all ish - didn't mean it to be and he probably hasn't after all!)
