spackrackman Posted August 7, 2006 Share Posted August 7, 2006 Hi all, Not that interesting, but i went to use my road angel today, noticed the fuse had gone in the plug, changed it, plugged it into the old ciggy socket and off went my air vent controls,fan,A/C,clock and fag lighter socket! fuse did not blow again in the angel lead(Iam guessing my lead must be buggered) All fuses under the bonnet seem fine, are there anymore I should be checking to get these controls back. Any advice would be welcome. jonnie Link to comment Share on other sites More sharing options...
squiffy Posted August 7, 2006 Share Posted August 7, 2006 drivers footwell mate, another box in there Link to comment Share on other sites More sharing options...
Pete Posted August 7, 2006 Share Posted August 7, 2006 In the driver footwell. Remove the panel to the right. Link to comment Share on other sites More sharing options...
heckler Posted August 7, 2006 Share Posted August 7, 2006 these some in the drivers footwell... thats where the fuses for a/c etc are Link to comment Share on other sites More sharing options...
heckler Posted August 7, 2006 Share Posted August 7, 2006 doh... little bit on the slow side there me thinks Link to comment Share on other sites More sharing options...
spackrackman Posted August 7, 2006 Author Share Posted August 7, 2006 Doh! cheers chaps.. This forum rocks! No more sweating for me! I did have a quick nosy around and did fiddle with a couple of flaps..... thought there should be something other than fuses under the bonnet. Again thanks JOnnie Link to comment Share on other sites More sharing options...
Pete Posted August 7, 2006 Share Posted August 7, 2006 doh... little bit on the slow side there me thinks You're not on your own. Link to comment Share on other sites More sharing options...
andrew7 Posted August 7, 2006 Share Posted August 7, 2006 Jonnie, I have a sat nav which also plugs into the cig socket for aux power. What I did find out was that you should never start the car with the sat nav plugged into the cig socket,i.e. if you stop the engine always unplug the cig socket lead to your unit and don't plug it back in until the engine is started again.... Apparently the electrics in these leads are not too sophisticated and a start up surge can fry them... Link to comment Share on other sites More sharing options...
