The Supra- it runs!!!!!
Supragal
  • Replies 82
Phew thats a relief... but yes that is what we are looking at (as tdr says) but they are all pushed in and the lights are still on. Any ideas?
i personally havent looked at this part of the supra but i'd remove the wires from each switch, one by one untill you find the culprit.
Rosie, if you close the doors and boot, the light will stay on, but are governed then by the timer circuit which should turn them out after a couple of minutes. However, at this point you can override the timer by locking the doors.
Sometimes an alarm with a plunger switch on the bonnet can bring on the interior light too. If this was faulty, it could keep the light on.
But you can also use the master switch on the light itself to override any of the switches/timers by just turning off the light completely. (It's the rocker one in the centre of the light.)
And as someone else said, make sure you have the light in the boot turned off too!
Hope to see it soon!
That turns off the interior light but not theignition barrel?
  • 3 weeks later...
