Clutch Pedal Woes....
imi
Hey Peeps
Need some help.
Yesterday while driving the car back I noticed that the clutch pedal behaving irratically.
Sometimes it wouldnt come back up all the way.
Sometimes when pressing the clutch, the pedal would be soft for the 1st inch of travel and then it would be ok (if that makes sense)
and then it would sort itself out for a few miles...
Car drives fine, doesnt seem like a slipping clutch or anything, picks up fine in 5th and 6th from low speeds...
What could it be??
Bleeding the clutch is simple, need 2 people though, the bleed nipple is very easy to get at with the car raised onto an axel stand front near side.
Just follow the clutch fluid pipe to the box, is right next to where it meets the box.
I had a similar problem on mine and I adjusted the cable that connects directly onto the pedal, in effect raising the bite point from close to the floor to the upper end of travel and it was fine after that. Still your problem may be totally different - just thought it was worth mentioning!
Cable? I was under the impression all supras had hydraulic clutches
