Graham Rudd Posted October 17, 2001 Share Posted October 17, 2001 Over the last couple of weeks my ABS warning light has started to occassionally remain lit after the ignition is switched on. I figured I could just ignore it for a while until I had time to find out what it means and get it sorted out, especially as there didn't actually seem to be anything wrong with the car. Unfortunately there definitely WAS an ill effect today, my RLTC went crazy, cutting my power as soon as I got going. I had to turn the Racelogic system off in order to drive it home. Does anybody have any idea what the likely cause of this might be? I guess from the RLTC end of things its seeing crazy results on the wheel speed sensor connections. I don't think its anything to do with the actual fitment of the RLTC as I've seen it happen a couple of times in the past, before the TC was installed. On those occassions it always disappeared if I switched the ignition off then on again though. If anyone could shed some light on this problem I would be greatly appreciative, all the more so if you can reassure me that I'm not going to be landed with the mother of all repair bills! I've had to shell out too much on repairs already. Thanks Graham Quote Link to comment Share on other sites More sharing options...
Phil Wall Posted October 17, 2001 Share Posted October 17, 2001 I guess the first thing to check is the speed sensors on each wheel. If it was intermittant it may be a dodgy connection. ABS relay could be a problem, you could try swapping the trac relay with the ABS and see if it reoccurs. (they are interchangable ) Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted October 18, 2001 Author Share Posted October 18, 2001 Thanks for that Phil, one more question though. Which one's the ABS relay? Erm.. for that matter which one is the Trac relay? Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 18, 2001 Share Posted October 18, 2001 First step is to check for any stored fault codes. Yours, J Quote Link to comment Share on other sites More sharing options...
Doughie Posted October 18, 2001 Share Posted October 18, 2001 If you look on the *inside* of the black plastic cover that clips onto the fuse&relay box, there's a diagram showing which fuse is which. I think the relay's are marked too. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted October 18, 2001 Share Posted October 18, 2001 Trac relay is in the plastic box on the left hand side of the engine bay. Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted October 18, 2001 Author Share Posted October 18, 2001 It certainly could be the relay, I scientifically wiggled all of the relays a little bit as I couldn't locate the ABS one (the diagram in the fuse box didn't help) and the problem has disappeared. So once again thanks to the people who responded, although I'm not over-confident that my piddling little pathetic fix is going to last long. Thanks Graham Quote Link to comment Share on other sites More sharing options...
Phil Wall Posted October 18, 2001 Share Posted October 18, 2001 Quote: from Ash on 10:17 am on Oct. 18, 2001[br] First step is to check for any stored fault codes. Yours, J Would that be the standard diagnostic TE1 to E1 connection and count the flashs on the engine light approach? Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 18, 2001 Share Posted October 18, 2001 Phil......... Yes. Yours, J Quote Link to comment Share on other sites More sharing options...
