kosmic Posted August 4, 2006 Share Posted August 4, 2006 Big thanks to Paul for fitting my decat pipe this morning. Excellent service and excellent prices!!! Highly recommended and will definetly be going back there. Car sounds awesome with the Tanabe on there. However i have (another) problem.. Car was boosting at stock to 0.7 bar and now only boosts upto 0.8 bar with the decat (jspec). I cant find and immediate boost leaks but its been underboosting since i reverted back to sequential mode from TTC a month ago...any ideas why it could be underboosting. before i did the TTc mode, i was boosting 0.8-0.9 bar all day everyday.??? Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 4, 2006 Share Posted August 4, 2006 Big thanks to Paul for fitting my decat pipe this morning. Excellent service and excellent prices!!! Highly recommended and will definetly be going back there. Car sounds awesome with the Tanabe on there. However i have (another) problem.. Car was boosting at stock to 0.7 bar and now only boosts upto 0.8 bar with the decat (jspec). I cant find and immediate boost leaks but its been underboosting since i reverted back to sequential mode from TTC a month ago...any ideas why it could be underboosting. before i did the TTc mode, i was boosting 0.8-0.9 bar all day everyday.??? the heat won't be helping with the boost levels Quote Link to comment Share on other sites More sharing options...
steb9780 Posted August 4, 2006 Share Posted August 4, 2006 Can I be cheeky and ask how much it was for the pipes including fitting, thanks! Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 the heat won't be helping with the boost levels True but witht he decat i should be boosting a lot more than it is already?? Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 4, 2006 Share Posted August 4, 2006 True but witht he decat i should be boosting a lot more than it is already?? have you removed both cats? If yes i would imagine Paul fitted a restrictor ring which isn.t holed correctly then Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 have you removed both cats? If yes i would imagine Paul fitted a restrictor ring which isn.t holed correctly then yes double decat, IIRC he fitted a 1.1bar res. ring Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 4, 2006 Share Posted August 4, 2006 yes double decat, IIRC he fitted a 1.1bar res. ring are you one for getting underneath your own car? If so, take the restrictor ring out and try it. If it boost OK then the restrictor ring will need the opening enlarged Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 are you one for getting underneath your own car? If so, take the restrictor ring out and try it. If it boost OK then the restrictor ring will need the opening enlarged Yep love doing my own stuff when i can. Will try that and see what happens. Cheers Lee Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 4, 2006 Share Posted August 4, 2006 Yep love doing my own stuff when i can. Will try that and see what happens. Cheers Lee just make sure you don't overboost with the restrictor out. Take it easy Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 just make sure you don't overboost with the restrictor out. Take it easy Will do mate. need to get some exhaust joining paste/gum to reseal the joints. Do Halfrauds sell it? Quote Link to comment Share on other sites More sharing options...
LeeT Posted August 4, 2006 Share Posted August 4, 2006 Will do mate. need to get some exhaust joining paste/gum to reseal the joints. Do Halfrauds sell it? yeh halfrauds or any motorfactors. i bought a mastic sized tube of it for £4 from my local motorfactors Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 4, 2006 Share Posted August 4, 2006 Will do mate. need to get some exhaust joining paste/gum to reseal the joints. Do Halfrauds sell it? Just a little test Sandeep, try reverting it back to TTC and see what that does, quick 5 min test. Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 yeh halfrauds or any motorfactors. i bought a mastic sized tube of it for £4 from my local motorfactors Cheers guys for the help. Will keep you all informed Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2006 Author Share Posted August 4, 2006 UPDATE: In the quest to solve the problem, wkdtime came round to help my diagnose the missing boost problem. First we tried the car in sequential mode, max boost was 0.8 bar. Then we tried it in TTC mode, max boost was 0.8 bar sustained(spiked to 1.0bar). Still the same. Next we disconnected the BOV and same,0.8 bar. So as LeeT suggested we took out the restricter ring out. Was a different car altogether. Now happily boosts to just under 1.0 bar, doesnt hit fuel cut and is running sweet as anything and feck me does it fly. cant wait to install the plugs,pump,FCD and start turning up the boost a little. Although it isnt peaking to 1.2+ bar as i though a jspec would, im still happy that it isnt hitting fuel cut without the restricter ring and boy has it brought back that smile to my face admist all the other problems the car is giving me. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 4, 2006 Share Posted August 4, 2006 Good news that its working again Sandeep I know different cars respond to decatting differently, but its doesn't sound right that you're not over boosting without the restrictor. Most jspec cars will over boost hugely (I hit 1.2bar in 2st and 1.4bar in 2nd, can't imagine what 5th would hit). This could indicate another issue with maybe a vsv or vacuum pipe work... Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 4, 2006 Share Posted August 4, 2006 Good news that its working again Sandeep I know different cars respond to decatting differently, but its doesn't sound right that you're not over boosting without the restrictor. Most jspec cars will over boost hugely (I hit 1.2bar in 2st and 1.4bar in 2nd, can't imagine what 5th would hit). This could indicate another issue with maybe a vsv or vacuum pipe work... Homer, theres quite a few members who dont over boost with double decat on J specs, Nic being one of the many that i can name. If there was a problem with he VSV it would have shown when the car was run in TTC as both the VSV and IACV are by passed...yet there was no difference. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 4, 2006 Share Posted August 4, 2006 Just to add, Damn Kosmics Tannabe sounds awsome with the double decat, so much better than the Nur Spec, one of the best sounding IMHO. Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 5, 2006 Author Share Posted August 5, 2006 Just to add, Damn Kosmics Tannabe sounds awsome with the double decat, so much better than the Nur Spec, one of the best sounding IMHO. Cheers Dude, damn it did sounded pretty awesome, like a WW2 bomber well chuffed with it. I went for a spirited drive last night and with the colder air was just starting to hit fuel cut Gota sort the pump,plugs & FCD out now. anyone recommend a boost controller? Quote Link to comment Share on other sites More sharing options...
Ark Posted August 5, 2006 Share Posted August 5, 2006 Good news that its working again Sandeep I know different cars respond to decatting differently, but its doesn't sound right that you're not over boosting without the restrictor. Most jspec cars will over boost hugely (I hit 1.2bar in 2st and 1.4bar in 2nd, can't imagine what 5th would hit). This could indicate another issue with maybe a vsv or vacuum pipe work... As some other people have said, not all the cars respond the same...last time I talked to Scooby, he said his was only doing 0.9 on a double decat and backbox... Quote Link to comment Share on other sites More sharing options...
Pete Posted August 5, 2006 Share Posted August 5, 2006 Keep an eye on it when it gets colder! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 7, 2006 Share Posted August 7, 2006 Definately sounds like something is up somewhere there mate, without a restrictor ring it should boost well over 1.2 bar......if you want us to take a look just give us a shout Cheers Paul Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 7, 2006 Share Posted August 7, 2006 Just to add, Damn Kosmics Tannabe sounds awsome with the double decat, so much better than the Nur Spec, one of the best sounding IMHO. Brings back all the memories of how good mine used to sound with decat and Tanabe Super Racing Medallion. IMO the Tanabe zorst is better than the Nur Spec in terms of sound AND build quality. Quote Link to comment Share on other sites More sharing options...
