Justin Posted February 21, 2004 Share Posted February 21, 2004 Bought one of these last weekend to bleed my brakes as the missus is getting fed up with ............ down.... up.....down......up......down......up ....................is it up?????? er ............. I said down............ don't shout at me!.................. goes in doors....... (try to resist the obvious comments ) So I bought a kit that you connect to your spare tyre and it pumps fluid from a bottle into the system when you open the bleed valve. Awesome........ I thought. Doesn't come with a Supra type bayonet brake reservoir cap fitting just the screw type ones so don't buy it boys and gals if you were going to Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted February 21, 2004 Share Posted February 21, 2004 Why would you need to keep bleeding your brakes? The only time your brakes need bleeding is if you have opened up a brake line and air has got into the system. Quote Link to comment Share on other sites More sharing options...
Justin Posted February 21, 2004 Author Share Posted February 21, 2004 1st time - Sevice 2nd time - Refurbed rear calipers 3rd time - Fitted Braided hoses 4th time - Refurbed front calipers 5th time - missus brakes needed refurbing Also a good idea to change after heavy track days etc. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted February 21, 2004 Share Posted February 21, 2004 Nuff said!! Quote Link to comment Share on other sites More sharing options...
