JamieP Posted August 3, 2006 Share Posted August 3, 2006 Anyone fitted one of these?? http://cgi.ebay.co.uk/Toyota-Supra-1993-1998-Short-Shifter-L-K_W0QQitemZ190014288260QQihZ009QQcategoryZ43120QQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
lockys96 Posted August 3, 2006 Share Posted August 3, 2006 cheap as hey, i got a feeling these wont last. hey, but what do i know Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2006 Author Share Posted August 3, 2006 Thats what i was thinking Link to comment Share on other sites More sharing options...
Guest dee_rz Posted August 3, 2006 Share Posted August 3, 2006 i've been told to stay away from these, in theory it should be great but most of these short shift kits can damage the gearbox as the throw is fairly short out of the factory and has been designed for a reason with that throw, apparently there is only a few short throw kits of high quality and there the ones that cost a hell of alot of wedge for what they do, i'd say don't bother, just learn to shift quicker .....without crunching the gears in Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 3, 2006 Share Posted August 3, 2006 Jamie I have a B&M one fitted to mine and quite frankly I wish I had not done it. Next time you are down have a try of mine and see what you think. PS mine cost $198. Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2006 Author Share Posted August 3, 2006 ok... thanks guys:) Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2006 Author Share Posted August 3, 2006 i've been told to stay away from these, in theory it should be great but most of these short shift kits can damage the gearbox as the throw is fairly short out of the factory and has been designed for a reason with that throw, apparently there is only a few short throw kits of high quality and there the ones that cost a hell of alot of wedge for what they do, i'd say don't bother, just learn to shift quicker .....without crunching the gears in I can shift quick thanks:) its just i like my toys;) http://www.mkivsupra.net/vbb/showthread.php?t=76813 Link to comment Share on other sites More sharing options...
Guest dee_rz Posted August 3, 2006 Share Posted August 3, 2006 Jamie I have a B&M one fitted to mine and quite frankly I wish I had not done it. Next time you are down have a try of mine and see what you think. PS mine cost $198. was going to say the b&m ones are meant to be of good quality and build but if this is the case .... feck that don't do it jamie Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted August 3, 2006 Share Posted August 3, 2006 I bought a similar one from ebay about 2 years ago and it's been fine since then. The one I got only really moved the pivot point up the shaft by about 5mm and then shortened the stick itself. It is fine for changing gears, and also allows me to change CDs when in 1st, 3rd and 5th now. Down side is that all the outer covers are now aluminium and they can get very hot in the sun, and can get very warm with hard driving due to the heat transfer from the gearbox. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted August 3, 2006 Share Posted August 3, 2006 Forgot to say that mine didn't come assembled and had no instructions so took a while of head scratching to figure out the correct method for assembly. Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2006 Author Share Posted August 3, 2006 ok thanks but im not going to bother with one now:) Link to comment Share on other sites More sharing options...
Guest lloydmcc Posted August 3, 2006 Share Posted August 3, 2006 i got a BnM i think its really good nice sharp changes Link to comment Share on other sites More sharing options...
Homer Posted August 3, 2006 Share Posted August 3, 2006 Jamie I have a B&M one fitted to mine and quite frankly I wish I had not done it. Next time you are down have a try of mine and see what you think. Got to agree with Greg here. The B&M one on mine is horrible, its coming out asap. You're welcome to take it for a drive on Saturday, but guess you've got the message by now Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2006 Author Share Posted August 3, 2006 yep i wont be fitting one:) Link to comment Share on other sites More sharing options...
Ulrik Posted August 20, 2006 Share Posted August 20, 2006 I was woundering if anyone has a C's 6 Speed Short Throw Shifter In their car Link to comment Share on other sites More sharing options...
pump gas pete Posted August 20, 2006 Share Posted August 20, 2006 I have a B+M. Its been fine . Link to comment Share on other sites More sharing options...
uk-rich Posted August 20, 2006 Share Posted August 20, 2006 I have a B+M. Its been fine . same here, no probs at all Link to comment Share on other sites More sharing options...
SteveL Posted August 20, 2006 Share Posted August 20, 2006 same here, no probs at all Yeh - same here - no problems at all - love it as its either in gear or not. But some people don't seem to like the 'notchy-ness'. Jamie - try someones first - it seems this is a love or hate thing Link to comment Share on other sites More sharing options...
pump gas pete Posted August 20, 2006 Share Posted August 20, 2006 I like the sound of Snick...Snick...Snick on short shifts.....ahhhhh Blissto!!! Link to comment Share on other sites More sharing options...
Ulrik Posted August 20, 2006 Share Posted August 20, 2006 So did you notice any difference from stock to B&M ? Bad part, good part? Link to comment Share on other sites More sharing options...
uk-rich Posted August 20, 2006 Share Posted August 20, 2006 good part-much shorter more direct shift, faster bad part-slightly more notchy, but not that bad at all Link to comment Share on other sites More sharing options...
Guest lloydmcc Posted August 20, 2006 Share Posted August 20, 2006 good part-much shorter more direct shift, faster bad part-slightly more notchy, but not that bad at all got to agree their i like it Link to comment Share on other sites More sharing options...
Ulrik Posted August 20, 2006 Share Posted August 20, 2006 Cheers guys Gonna see if i can get a good price one. I would really one a C´s , but seem hard to get and cost alot Link to comment Share on other sites More sharing options...
SUPRA TT Posted August 20, 2006 Share Posted August 20, 2006 hi every one i have one i seems to be good and its a bit noisy its true but i like the shift .i bought it from ebay with no instructions. but i did it Link to comment Share on other sites More sharing options...
