Short shifter
JamieP
Guest dee_rz
i've been told to stay away from these, in theory it should be great but most of these short shift kits can damage the gearbox as the throw is fairly short out of the factory and has been designed for a reason with that throw, apparently there is only a few short throw kits of high quality and there the ones that cost a hell of alot of wedge for what they do, i'd say don't bother, just learn to shift quicker :p :D .....without crunching the gears in :D
I can shift quick thanks:) its just i like my toys;)
http://www.mkivsupra.net/vbb/showthread.php?t=76813
Guest dee_rz
Jamie I have a B&M one fitted to mine and quite frankly I wish I had not done it.
Next time you are down have a try of mine and see what you think.
PS mine cost $198.
was going to say the b&m ones are meant to be of good quality and build but if this is the case .... feck that :tongue: don't do it jamie :D
I bought a similar one from ebay about 2 years ago and it's been fine since then. The one I got only really moved the pivot point up the shaft by about 5mm and then shortened the stick itself. It is fine for changing gears, and also allows me to change CDs when in 1st, 3rd and 5th now.
Down side is that all the outer covers are now aluminium and they can get very hot in the sun, and can get very warm with hard driving due to the heat transfer from the gearbox.
Got to agree with Greg here. The B&M one on mine is horrible, its coming out asap. You're welcome to take it for a drive on Saturday, but guess you've got the message by now ;)
  • 3 weeks later...
Guest lloydmcc
good part-much shorter more direct shift, faster
bad part-slightly more notchy, but not that bad at all
got to agree their
i like it
