13 and 34 engine faults query
robert_gray
Hi, Im having a few possibly minor problems with my jap twin. Its a 96 if it make a difference. I have two engine faults that only show up when idling out of gear (park or neutral). The two faults apper at the same time after a few second if idling.
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13920&d=1112558346
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13922&d=1112558346
Here are the links to the engine management fault codes.
The only thing that i have managed to check at the moment is the timing belt which was changed about 12,000 mile ago, its still tought and has not teeth missing. Im and engineer but i know very little about engines so a point in the right direction would be good.
I was wondering if there was a few things that i could check myself before i have to acrt it off the get it checked over properly, with a bit of guidence i could probably do it but im just not sure on where to start
Thanks
  • 1 year later...
