cntt Posted August 2, 2006 Share Posted August 2, 2006 does this diagram at the in this pdf file apply to all MKIV supra's or just the 96 on? jap or uk or usa models? http://www.mkivsupra.net/vbb/showthread.php?t=72844 the diagram showing is referring to U.S. as it is LHD layout after figuring out that the location of the left and right are the opposite. anyone got some info about this? if the wiring is not the same for any supras before 96, or different for jap, anyone know where I can find the correct one? thanks Link to comment Share on other sites More sharing options...
terribleturner Posted August 2, 2006 Share Posted August 2, 2006 Im pretty sure it's the same. I have been reffering to it alot over the last month and has helped me out about 90% of the time Link to comment Share on other sites More sharing options...
cntt Posted August 3, 2006 Author Share Posted August 3, 2006 I just checked the layout of the switches on the diagram which is the USDM ones(LHD), and they are not the same as the layout of the switches for the jspec ones, just thinking there is a possiblity that the pin out could also be different. also I do have 2 wires left over from the loom which was plugged in to them orange plugs. and I followed the wiring diagram to re wire the plugs on the switches unit, and nothing works, before I do that, I had 2 switches that would work for a short time when turn the key on, I'm thinking there might be a error code feed back to ecu as to some in-correct wiring, and it disable itself all together then, but now, just nothing, 3 LEDs are on the fan switch constantly as well. Link to comment Share on other sites More sharing options...
