question on wiring diagram in download section
cntt
does this diagram at the in this pdf file apply to all MKIV supra's or just the 96 on? jap or uk or usa models?
http://www.mkivsupra.net/vbb/showthread.php?t=72844
the diagram showing is referring to U.S. as it is LHD layout after figuring out that the location of the left and right are the opposite.
anyone got some info about this?
if the wiring is not the same for any supras before 96, or different for jap, anyone know where I can find the correct one?
thanks
I just checked the layout of the switches on the diagram which is the USDM ones(LHD), and they are not the same as the layout of the switches for the jspec ones, just thinking there is a possiblity that the pin out could also be different.
also I do have 2 wires left over from the loom which was plugged in to them orange plugs.
and I followed the wiring diagram to re wire the plugs on the switches unit, and nothing works, before I do that, I had 2 switches that would work for a short time when turn the key on, I'm thinking there might be a error code feed back to ecu as to some in-correct wiring, and it disable itself all together then, but now, just nothing, 3 LEDs are on the fan switch constantly as well.
