Easy (and quick) ways to increase boost?
Homer
With the hot weather the boost level is dying on my car. It hits 1.25 bar fuel in 4th/5th gear in winter but is now struggling to reach 0.9 bar. AFR's are still rich (mostly aroung 10.5) so it can certainly take a lot more boost despite the heat.
So, how can I cheaply and quickly increase the boost of the car before the weekend? Removing the resricitor ring is out the question since it hits 1.3 bar in 2nd!
I'm off to Santa Pod at the weekend so would like to increase to 1.2 bar for the event.
bleed valve?:search:
Was thinking the same thing... Not sure who can ship one before Sat...
Also I've got no idea how to set one up. Couldn't find anything on a search since almost everyone says not to use them!
Whip off the hose from the wastegate actuator. That'll sure increase boost (too much). Put a bleed valve in line with it though so that some of the air goes where it should and actuates the wastegate, and you'll be sorted.
Halfords for the bleed valve. Took a lot of explaining, mostly about RS Turbo boys (and taps) for them to go upstairs and dig one out though.
I have the same problem and will be interested to see how you get on...keep us posted...;)
'Mercx' : Just been looking at your threads from a few months ago. Did you go for a bleed valve or manual boost controller? How have you found it, any problems etc??
Race Fuel are you BPU already? if your intercooler is knackered as well this wont help
Homer, I've got my old one here if you want it? (just sort us out a beer or something next time I see you!)
pm me your address matey and I'll try and get it in the post to you!
That'll be superb if you could Adi!
Are you at pod this Saturday, could pick up from you then? If I can't buy a beer I'll hand over some beer tokens :D
Homer whats the state of your I/C, the temps alone shouldnt bring your boost down to 0.9Bar from 1.2Bar, TBH at most with a healthy I/C the drop in boost should be around 0.05-0.1Bar.
Im in West London where we see some of the hottest temps and my boost has only dropped by 0.1Bar.
Be careful with upping the boost to compensate for the drop in boost if your I/C isnt in good shape for obvious reasons.
IC is mint, its a Greddy 3-row fully ducted from a do-luck front. This is the 3rd summer my car has been BPU and I get the same pressure drop in hot temps every time (Thought its been much better the last 2 due to the FMIC fitment).
Im stumped mate as ive never noticed such a drop, i say Lazy turbos:D
agree with this....i havent noticed any significant drop in boost.
Maybe we're talking different speeds here? Below 3rd there's no real difference, but the drop off is really noticable in 4th, 5th and 6th (100mph and above).
