silvershark44 Posted July 31, 2006 Share Posted July 31, 2006 I have a jap spec auto tt 1994 fully uk converted to mph inc clock however the active spoiler comes down at 90mph as a result. How can I get this sorted so it comes down at 60 or whatever it should be normally. I want to keep it active and not just lock it down. I dont want to remove it either as i can really tell the difference with it on. So how can i get this sorted?? is there any ecu type thing i need to buy to correct this? Rewiring?? thanks:search: Quote Link to comment Share on other sites More sharing options...
carl0s Posted July 31, 2006 Share Posted July 31, 2006 I think you need a better speed-converter thingy. Whatever they're called. You need one like the Thor one which outputs both a modified and an un-modified speed signal. The unmodified signal goes to the bits that control the speed-sensitive power steering, active-spoiler, and whatever else needs to know the real road speed. Something like that anyway. Quote Link to comment Share on other sites More sharing options...
Homer Posted July 31, 2006 Share Posted July 31, 2006 Spot on Carlos (in a round about way ) If the Active spoiler is deploying at the wrong speed your steering will also be very light at higher speeds - not a nice feeling. Quote Link to comment Share on other sites More sharing options...
silvershark44 Posted July 31, 2006 Author Share Posted July 31, 2006 ok so if i contact thor racing they should be able to get me a new convertor?? i assume theres is the best around. only the best will do for my supra Quote Link to comment Share on other sites More sharing options...
Homer Posted July 31, 2006 Share Posted July 31, 2006 ok so if i contact thor racing they should be able to get me a new convertor?? i assume theres is the best around. only the best will do for my supra Yes indeedy, they're used my a huge amount of people on here. In fact in all my time here I've not seen anything but the Thor unit even mentioned! Quote Link to comment Share on other sites More sharing options...
Homer Posted July 31, 2006 Share Posted July 31, 2006 http://www.thor-racing.co.uk/DSC+TSD_Combined-DSC+TSD.asp Quote Link to comment Share on other sites More sharing options...
silvershark44 Posted July 31, 2006 Author Share Posted July 31, 2006 ok thanks i know this may vary but do you think that it will be easy to swap out the old convertor unit for the thor racing one?? or am i likely to have trouble as its already been converted? Quote Link to comment Share on other sites More sharing options...
