Unhealthy noise coming from engine!
jamesmark
Looking for some help and I am sorry for the description
I have a rattle coming from the left bank of the engine it is there on cold start and goes when hot but comes back again at about 2.5k revs, the noise I can only describe as a bit of metal that is loose and rattling about against thick metal.
I tried to get a sound clip but you cant hear it well on the clip as the engine drowns it out but here is an attempt best heard at 2 seconds and 10 seconds but is faint Link
Normally, the impossible sounds we diagnose at once, but miracles take a littke longer :D
Get it down to someone who can actually hear the sound without it being attenuated by the damn AGC on the camcorder.
Hope it's not too serious ;)
I have mate and he cant work it out, so he is going to get the came covers off etc and take a look inside as he is stumpted
My better half's father he is a mechanical and electrical engineer 30 years timeserved and he has never heard this noise before I hope its not too serious
Try using a breaker bar and pressing it against your ear and various points on the engine, it might help you pin point the noise.
Or a stethascope (sp?)
The mechanic had a piece of garden hose and i wondered what it was for till he told me, he has done that but cant pin point it
Does it rattle on revup, coastdown, or while maintaining an rpm?
-Ian
On idle you cant hear it apart from on a cold start (waiting for engine to cool right down to have another go at filming it) when hot you dont hear but rev up to 2.5k the rattling noise starts and goes in time with the engine as you can on up the revs and stop we you bring the revs back under 2.5k
As for driving it does do it on cold and yiou can here it but when hot you cant hear it unless you hang yourself out the window.
  • 4 months later...
you could try the front or rear knock sensors located on the passenger side of the block, both are about midway down and run paralel with each other,sorry but i cant hear your clip at the moment but i know these knock badly when gone,and its quite a simple task to elliminate.
hope this helps and ill try to get ur clip working
Cool mate as you said process of elimination, try double clicking on the clip that seemed to work after leaving it for a while.
