Prof. Monkey Posted July 31, 2006 Share Posted July 31, 2006 Hi as some of you know I have been renovating a 205GTI, 1.6, 89G, 80,000 genuine miles. Last week, I was going to get my MOT done, when the car just died on me and refused to start again! after about 10-15 minutes the car started and I continued to drive, where the car dies again! It always seems to be when it comes to operating temperature. Oil pressure is good, plenty of clean oil in the sump, new filter and plugs, checked most of the connections are intact. Has anyonegot any ideas of how I can remedy this problem. Oh I was told that the fuel pump relay can cause stalling, so I replaced with a brand-new one, also replaced the fuel pump with a working one out of another car, I tested it before fitting and it was fine.. Any suggestions would be greatly appreciated.... Quote Link to comment Share on other sites More sharing options...
ECK Posted July 31, 2006 Share Posted July 31, 2006 check for any cracks in the inlet manifold there prone to this and it messes with the air fuel mixture. check the distributor too for cracks and wear in the cap!!! Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted July 31, 2006 Author Share Posted July 31, 2006 Will do, thanks for that! Guess when it is hot the dizzy could be expanding. Quote Link to comment Share on other sites More sharing options...
Mike M Posted August 1, 2006 Share Posted August 1, 2006 Not that it's any help but my g/fs 205 1.1 had a similar problem just before it got sold, drive 40 odd mile and then it would just cut out and wouldnt start till it cooled a bit. Good luck with the fault finding, we never got to find out what it was. Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted August 1, 2006 Author Share Posted August 1, 2006 Thanks I will find what is up with the thing eventually! Quote Link to comment Share on other sites More sharing options...
