UK Soop Front Spoiler Gone AWOL !
Fire148
When the Veilside kit was fitted to my uk soop, the switch inside that controls the front spolier wasn't sorted so I have a constant flashing light on the switch, and the warning triangle on the speedo.
Apparently you can get a clip to fix it .... anyone know where from ?
Mornin' and welcome to the BBS.
You can join two of the wires together at the spoiler plug, the YELLOW and the PURPLE/YELLOW, and this will cure the problem, but you'll have to make sure the spoiler button is in the off position. This just fools the ECU into thinking the spoiler is in the 'parked position'
Or, behind the radio, on the top of the tunnel, right at the back of the dashboard, you'll find two silver ECU's. the one at the botton is the ABS, the one on the top is the active spoiler ECU. You can either unplug or remove this, and the problem will go away.
Hope that helps :)
