Terminator Posted July 29, 2006 Share Posted July 29, 2006 How can you tell if injectors are high or low impedance? I have a volt meter, what test can I do? cheers Quote Link to comment Share on other sites More sharing options...
Miguel Posted July 29, 2006 Share Posted July 29, 2006 Set your Meter to read resistance ( ohms) and test the resistance between the 2 pins on the injectors. High imp are Circa 13-15 Ohm's IIRC And Low impedance 3-4 ohm's IIRC Quote Link to comment Share on other sites More sharing options...
dandan Posted July 29, 2006 Share Posted July 29, 2006 Yep spot on. I've used low's meausring down at 1.2 Ohms and high impedence ones at 12 Ohms though. Quote Link to comment Share on other sites More sharing options...
