Tattooman Posted July 28, 2006 Share Posted July 28, 2006 Should I be worried about this warning light ??? I have no owners manual / Hand book.... This has only happened since I wired in my (Top Speed De- Limiter) after giving the Supra a bit of Wellie Last night.... It doesn't stay on after parking up and re-starting the car ??? It is the warning light that is on the far left of the dark tinted panel to the right of the steering wheel by the air vent and it kinda looks like an outline of an old style camcorder from a side profile. I had to unplug the ECU and remove it from my car in order to tap into the 4 wires for TSD installation. The Top Speed De-Limiter works fine by the way. Any ideas or what the sensor light is ??? Here is a really crappy piccie of the light taken with my Camera Phone, it's not very good.... Quote Link to comment Share on other sites More sharing options...
fredm Posted July 28, 2006 Share Posted July 28, 2006 Hi , thats the "malfunction indicator light" did you by chance have the ignition switched "on" when you disconnected the ecu? Reset the ecu and it should go away, disconnecting the battery for a couple of minutes usually works. Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 No I didn't have the ignition switched on when I disconnected the ECU. I just find it strange that if I went out in it now it wouldn't come on straight away it would be only after putting your foot down for a while ??? Quote Link to comment Share on other sites More sharing options...
carl0s Posted July 28, 2006 Share Posted July 28, 2006 I think it's meant to be a picture of an engine. Perhaps you wired it up wrong? Quote Link to comment Share on other sites More sharing options...
imi Posted July 28, 2006 Share Posted July 28, 2006 when u bring the car to a standstill, does the light go off??? Does it come on at a certain speed, or certain rev + speed ? Quote Link to comment Share on other sites More sharing options...
Fifty Posted July 28, 2006 Share Posted July 28, 2006 Read the code - do a search on how to do this - this is a general engine malfunction light and I would say a code has been stored. 2 min job to check - you need only paperclip and to know how Rich Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 I think it's meant to be a picture of an engine. Perhaps you wired it up wrong? Bad piccie of an Engine me thinks...LOL I wired it in right. Everything works ok and de limiter works ok too ?? Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 when u bring the car to a standstill, does the light go off??? Does it come on at a certain speed, or certain rev + speed ? When you bring the car to stand still it stays on, but if you turn ignition off and re-start the car than it stays off until you have driven for a while and maybe given it some heavy right foot ??? So hopefully it can't be anything too serious then I hope ?? Quote Link to comment Share on other sites More sharing options...
Fifty Posted July 28, 2006 Share Posted July 28, 2006 lo why dont you just see what the code says then you will know? Rich:) Quote Link to comment Share on other sites More sharing options...
Paul_SWZ Posted July 28, 2006 Share Posted July 28, 2006 tattooman did you used to have a skyline, zed ? Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 tattooman did you used to have a skyline, zed ? Yes mate I used to have a Skyline and a ZX.... Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 I've just disconnected the battery to reset the ECU and I'll try it tomorrow on my way to work and see if the Light comes on again. I have just done some searches for the ECU codes / diagnosis and if it comes on again then I guess I'll have to attempt the Paperclip test to see what codes it comes up with... Quote Link to comment Share on other sites More sharing options...
Steve W Posted July 28, 2006 Share Posted July 28, 2006 Mine used to come on if i " held the engine speed above 3,000 for more than ~8 seconds" it was one of the Speed Sensors . try keeping the revs below 3,000 for the first part of journey, then, on a reasonable straight, hold it at 3,500 for 10 seconds ?? (could be ANYTHING though....trivial...or SERIOUS so do find out !) Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 28, 2006 Share Posted July 28, 2006 Mine came on when I'd only partly wired in my speedo convertor & top speed delimiter - it was because it was getting different speed signals from different sensors. What TSD have you used?? Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 Mine came on when I'd only partly wired in my speedo convertor & top speed delimiter - it was because it was getting different speed signals from different sensors. What TSD have you used?? I have used the one from Miami GT who are supplied by Thor (TRL is on the unit) Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 28, 2006 Share Posted July 28, 2006 I have used the one from Miami GT who are supplied by Thor (TRL is on the unit) Mine is the Thor combined TDS & speedo/odo convertor. Hmmmm..... it should be fine. My brain isn't working too well today as I'm shattered. I'll keep thinking. Actually - have you tested to see if you can go over the 112mph/180kph limit? If you've not wired it in properly or the unit has a crappy connection/no power I guess it would have no signal, which would give you that error. Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 28, 2006 Author Share Posted July 28, 2006 I made sure all the connections were spot on using Bullet Connectors and there was a TRL Fuel Cut defender that I tapped into the Red wire for power from the Ignition, I earthed directly to an upright by the lower door hinge and then tapped into the other 2x wires as per the instructions. The De- Limiter works ok and I have had my car upto 140mph so I know it did the job ok .... Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 29, 2006 Author Share Posted July 29, 2006 OK, heres the latest on my car... After resetting the ECU it made no difference at all. I drove my car to work today and for approx 3 miles I didn't go over 3000rpm and just as I got close to 3000rpm and held it there for a few seconds on came the warning light again ??? I pulled over for fuel after 1 mile filled up re started again and NO warning light came on. After work I was playing around with setting up my boost controller and NO warning light driving fairly hard boosting at 1.1 bar, coming into town from Dual Carridgeways and slowing right down into a 30mph area and driving really slowly on came the Bloody Warning light again !!! It's doing my nut in as it just seems to be really random and has no pattern to it at all ??? Anyone ??? Quote Link to comment Share on other sites More sharing options...
carl0s Posted July 30, 2006 Share Posted July 30, 2006 Are you able to temporarily disconnect the SLD? Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 30, 2006 Author Share Posted July 30, 2006 Are you able to temporarily disconnect the SLD? I suppose I could quite easily as I wired it in.... But then that would disconnect the odometer totally as it's the wire that you have to cut/tap into in order to fit it ??? Quote Link to comment Share on other sites More sharing options...
SteveR Posted July 30, 2006 Share Posted July 30, 2006 I'm no expert, but have you checked for error codes? Is the the sort of thing that would get recorded? Quote Link to comment Share on other sites More sharing options...
Dave Posted July 30, 2006 Share Posted July 30, 2006 I suppose I could quite easily as I wired it in.... But then that would disconnect the odometer totally as it's the wire that you have to cut/tap into in order to fit it ??? see this t/man http://www.mkivsupra.net/vbb/showthread.php?t=72588 Quote Link to comment Share on other sites More sharing options...
Homer Posted July 30, 2006 Share Posted July 30, 2006 I suppose I could quite easily as I wired it in.... But then that would disconnect the odometer totally as it's the wire that you have to cut/tap into in order to fit it ??? Mate, the light means an error code has been generated, in order to find out what’s wrong you need to retrieve the error code (As mentioned at the start of this thread). Click on the link 'error code' and it will explain how to retrieve the code and the meaning. Until you do that its pointless speculating further. Quote Link to comment Share on other sites More sharing options...
leelbuk Posted July 30, 2006 Share Posted July 30, 2006 OK, heres the latest on my car... After resetting the ECU it made no difference at all. I drove my car to work today and for approx 3 miles I didn't go over 3000rpm and just as I got close to 3000rpm and held it there for a few seconds on came the warning light again ??? I pulled over for fuel after 1 mile filled up re started again and NO warning light came on. After work I was playing around with setting up my boost controller and NO warning light driving fairly hard boosting at 1.1 bar, coming into town from Dual Carridgeways and slowing right down into a 30mph area and driving really slowly on came the Bloody Warning light again !!! It's doing my nut in as it just seems to be really random and has no pattern to it at all ??? Anyone ??? Don't think it should be rpm you are worried about, I think its speed. This happenned to me every time I went over about 60-80mph for a few seconds and the engine warning light came on as well as the MIL light and woundn't go off untill I switched engine off and back on again. Also active spoiler wouln't automatically work too. I checked the error codes and it turned out to be error 42 - something to do with a speed sensor. Found out it was just 1 wire that had come lose. Best to check error codes, dead easy to do and gives you a clue where to check next. Quote Link to comment Share on other sites More sharing options...
Tattooman Posted July 31, 2006 Author Share Posted July 31, 2006 Thanx a lot all you guys, I will do that tomorrow when it has stopped raining and hopefully get to the bottom of this. Thanx again.... Quote Link to comment Share on other sites More sharing options...
