Vaughany Posted February 17, 2004 Share Posted February 17, 2004 On the left hand side of the engine bay (if you are standing at the front of the car facing the engine) there is a fuse box that contains large fuses for Traction Control I think. Can someone tell me how many fuses this should have in it. It looks like it should have 4 but mine only has 3. As you look at the box from the right wing, the top left fuse is missing. Is this a spare or something, I have not noticed any problems so if a fuse should be there, god knows what it does. Anyone help me with this? Cheers Quote Link to comment Share on other sites More sharing options...
Guest ateal Posted February 17, 2004 Share Posted February 17, 2004 Don't worry mine is the same, so is my mates & every other supra i've seen. Like yourself, I've always wanted to know what's missing, I hope someone can answer this one. Cheers. Quote Link to comment Share on other sites More sharing options...
Vaughany Posted February 18, 2004 Author Share Posted February 18, 2004 Ateal Thanks, my mind is a little bit more at ease knowing that my Sup is not the only one missing the fuse. Not sure what it could be for but still very curious. Cheers Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 18, 2004 Share Posted February 18, 2004 The large fuses are actually relays. If you ever spot a hole where you think a fuse or a relay should be, check the slots where the prongs push in - if there are metal contacts in the lot, you need a fuse. If not, you don't You'll not find any contacts in the 4th slot in that little relay housing uness you've got an NA I believe. -Ian Quote Link to comment Share on other sites More sharing options...
