MOT failure, advice needed
trooper
could be the sensor I guess. I will look at it and get it checked by Toyota.
I wouldn't use Toyota fella, they are expensive and not really the best guys to use.
You can have a look at the sensor yourself it doesn't take much effort.
Have a search for o2 sensor you should find a little guide.
I sprayed the bolts with wd40 a couple of hours before i removed it just to make sure it undone easier.
It is about 10 minutes work to remove.
A new o2 sensor is about £80.
Clean it in lemon juice overnight then spray with brake cleaner to remove the lemon residue then refit.
Resetting the ecu is even easier, remove the 2 fuses in the engine bay fuse box.
Before you put the car in for an MOT make sure the 2nd cat is up to temperature, take the car for a run just before hand.
If that doesn't work, put a post up in members chat asking for a friendly MOT tester ;)
I agree with above, take it for a good thrash before the mot, get the cats good and hot.
Also something that has helped me in the past is chucking a bottle of that fuel additive in you tank (redex, nitrox, I can't remember what its called)... I know it sounds like bulls**t but it does actually help your emmisions a bit.
Mine just passed its MOT yesterday... double decat going in tomoz :D
bad news I'm afraid. The Toyota guys couldn't get the emissions down either.
They checked all the sensors but the CO was still 2.6%. They sent me packing with a bottle of fuel additive and told me to go for a thrash and come back tomorrow. Can't see it passing though to be honest.
Any other suggestions???
