strange brake question
Rob Davey
I'm ready to get beaten up over these questions but I’m going to ask anyway...
Are the UK rear 2 pots better than the Jspec front 2 pots?
If they are can you fit the rear UK spec to the fronts of a jspec setup to improve braking?
:shock:
That would involve fitting the rear discs to match to the front of the car, which i would assume would not work. bearing in mind the drum inside the disc, it would probably dick up the offsets etc.
fit UK fronts.
