TRD3000GT Posted July 27, 2006 Share Posted July 27, 2006 Just wondering what you guys consider to be optimum oil temprature... The from - to.. I this heat Im showing 80 - 95-100 at times.. Link to comment Share on other sites More sharing options...
Ray Posted July 27, 2006 Share Posted July 27, 2006 Thats what temp range mine is normally at too... I heard that its good to get it over 100 every now and then so that moisture in the oil boils off... Link to comment Share on other sites More sharing options...
JohnA Posted July 27, 2006 Share Posted July 27, 2006 It's fine, you don't want it over 120C very often though. Depends on the oil age as well as if it is fully synth. Link to comment Share on other sites More sharing options...
SimonB Posted July 27, 2006 Share Posted July 27, 2006 Depends where your sensor is. Temps are quite a lot lower in the bottom of the sump than by the oil filter for example. Link to comment Share on other sites More sharing options...
Lebsteif Posted July 27, 2006 Share Posted July 27, 2006 What temp should it have when the sensor is at oil filter? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 27, 2006 Share Posted July 27, 2006 Depends where your sensor is. Temps are quite a lot lower in the bottom of the sump than by the oil filter for example. Very true, mine are around 110C on boost and thats not in these temps. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 27, 2006 Share Posted July 27, 2006 I've only ever had mine upto 107.2 in this heat on a WOT pull on the motorway, my problem is the 117 degree water temperature.... Link to comment Share on other sites More sharing options...
JamieP Posted July 27, 2006 Share Posted July 27, 2006 my temp sensor is in a plate between the oil filter and i get a max reading of 110 on a spirited drive:) Link to comment Share on other sites More sharing options...
terribleturner Posted July 27, 2006 Share Posted July 27, 2006 Mine hit 130 just before my bottom end went Link to comment Share on other sites More sharing options...
bignum Posted July 28, 2006 Share Posted July 28, 2006 ive seen 117 on a trackday, driving hard for 5,6 laps thats with the sensor in a sandwich plate, my bro ran a ford v6 upto 140 on semi synth oil and lets just say it developed a knock on the bottom end lol.i think with good quality oil your ok upto 120d/c short term ,,? Link to comment Share on other sites More sharing options...
tDR Posted July 28, 2006 Share Posted July 28, 2006 According to Silkolene the Pro S 10W50 is good to 120 deg C and club oil analysis over on sxoc.com has shown cars used on track running this oil at temps higher than this without problems. Think Oilman (Opie Oils) then asked Silkolene's head chemist guy about max temp of this oil and they reckoned it was good up to 140 deg C! Link to comment Share on other sites More sharing options...
Prof. Monkey Posted July 28, 2006 Share Posted July 28, 2006 ive seen 117 on a trackday, driving hard for 5,6 laps thats with the sensor in a sandwich plate, my bro ran a ford v6 upto 140 on semi synth oil and lets just say it developed a knock on the bottom end lol.i think with good quality oil your ok upto 120d/c short term ,,? Think the plate raises the temperature due to the sensor being housed in metal.... Mine hits 120 on the gauge regularly, but I have seen somewhere that the sandwich plate, naturally raises the temp... Link to comment Share on other sites More sharing options...
