Guru Posted July 26, 2006 Share Posted July 26, 2006 Local Toyota (Blackburn) garage failed my Supe tonight on emissions. BPU withoput the cats in and she failed on that and front tyres. Gonna get her retested with the one cat in and pray she passes. Any reccomendations on decent tyres before I use the search button? Quote Link to comment Share on other sites More sharing options...
Ian R Posted July 26, 2006 Share Posted July 26, 2006 Goodyear GSD 3's get my vote Quote Link to comment Share on other sites More sharing options...
wkdtime Posted July 26, 2006 Share Posted July 26, 2006 Ask them what data they used for the Emissions? State its not a UK spec...Did they use your VIN? Quote Link to comment Share on other sites More sharing options...
Ian R Posted July 26, 2006 Share Posted July 26, 2006 Ask them what data they used for the Emissions? State its not a UK spec...Did they use your VIN? Good point as J-spec cars before '95 don't require cats AFAIK Quote Link to comment Share on other sites More sharing options...
Guru Posted July 26, 2006 Author Share Posted July 26, 2006 On the paperwork they have the VIN so I guess they used it. The CO limit they used was 0.30% max at fast idle if that helps (I scored 0.71%). I have the Bridgestone Potenza RE-01's which aren't that bad but nothing to compare to really Quote Link to comment Share on other sites More sharing options...
Paul_SWZ Posted July 26, 2006 Share Posted July 26, 2006 I wouldnt take it to a main dealer if I was you just find a specialist that might let the emmisions slide a little LOL I know A good man in somerset LOL Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 26, 2006 Share Posted July 26, 2006 I have the Bridgestone Potenza RE-01's I had these and rate them as poor. They haven't made them for some time. As far as your MOT is concerned, 1 cat should pass no problem. Quote Link to comment Share on other sites More sharing options...
Simon Posted July 26, 2006 Share Posted July 26, 2006 What we need is to know of Supra friendly MOT stations. Mines a 93 JDM and failed because it didn't have a cat fitted and also emissions. The new system requires the tester to input the engine model from the vin plate. 2jz-gte. This will bring up uk specs and there is no arguement with them about this, trust me I tried. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 26, 2006 Share Posted July 26, 2006 Alternatively, just make your cars road legal! Quote Link to comment Share on other sites More sharing options...
garetheves Posted July 27, 2006 Share Posted July 27, 2006 PM'd you Guru. Quote Link to comment Share on other sites More sharing options...
Guru Posted July 27, 2006 Author Share Posted July 27, 2006 Thanks Gaz I will try them Quote Link to comment Share on other sites More sharing options...
