RICHARDA Posted July 26, 2006 Share Posted July 26, 2006 Today I took the wheels off my car to give them a thorough clean and polish, so I thought I would use this opportunity and weigh them on the bathroom scales. Cripes, 23.8kg for the fronts and 24.5kg for the rears. (Wheels and tyres together). Thats nearly 100kg, I guess alot more than stock adding to the unsprung weight. Wheels are Azev M in 18" - 8.5 front and 10" rears with F1's allround. I had some old 18" tyres kicking about and weighed these at 10kg each so the wheels themselves are around 14kg each. Does anybody including traders know of any LIGHTWEIGHT 18's with a flat five spoke design (deep dish) in as near to stock offset as possible with correctly sized hubs, ie no hub centric rings etc or spacers which will clear UK brakes? Any ideas? Many thanks Rich Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted July 26, 2006 Share Posted July 26, 2006 Thats seems like a lot. I wonder how much standard wheels weigh? Quote Link to comment Share on other sites More sharing options...
Stonkin Posted July 26, 2006 Share Posted July 26, 2006 Thats a lot, mine are about 8.5 each Quote Link to comment Share on other sites More sharing options...
colsoop Posted July 26, 2006 Share Posted July 26, 2006 Those weights aren't too bad. Stock weights: Front with tyre: 20.84 kg Rear with tyre 24.72 kg Quote Link to comment Share on other sites More sharing options...
RICHARDA Posted July 26, 2006 Author Share Posted July 26, 2006 I feel better already. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 26, 2006 Share Posted July 26, 2006 Tyres are very heavy regardless of what the rims weigh. Quote Link to comment Share on other sites More sharing options...
Guest McMsk Posted July 26, 2006 Share Posted July 26, 2006 just weighed mine CCW 505A 19 Inch with Continental Sportcontact 2 Front 265/30 R19 rim with tire 22.1 kg Back 315/25 R19 rim with tire 22.2 kg Strage that the weight difference is so small, but i weighed them like 10 times, left and right Quote Link to comment Share on other sites More sharing options...
JohnA Posted July 26, 2006 Share Posted July 26, 2006 Even if the full wheel/tyre combo weighs the same as the stock 17", it will feel heavier to the suspension because most of the weight is further away from the centre. Quote Link to comment Share on other sites More sharing options...
merckx Posted July 26, 2006 Share Posted July 26, 2006 The C of G is still in the centre of the wheel! Gyroscopic forces won't be the same though. Quote Link to comment Share on other sites More sharing options...
JohnA Posted July 27, 2006 Share Posted July 27, 2006 Gyroscopic forces are the *most* important, and those will be higher (they go up by the square of wheel rpm) Unsprung weight is the next most important factor and that is dependent on total weight indeed. The real issue however is traction, the real reason behind such an 'upgrade'. Now that might not be as improved as one might expect. It might even be worse than that of a stock 17" setup done right. You have to make sure that the rubber is in uniform contact with the tarmac under all dynamic conditions - and that could take a lot of work to achieve when fiddling with the suspension and huge wheels. Quote Link to comment Share on other sites More sharing options...
