Various parts
JohnK
All from a ’97 facelift model
SET OF FACELIFT DASH PANELS (excluding gear surround) £75 – manual gear surround may be available to swap for good condition non facelift manual panel Awaiting conformation
Rear wiper motor £20
Aerial relay £5
Central locking ECU £10
Air con/heater ECU SOLD
Air con/heater switches £20
Slip control switch £3
Top left dash warning cluster £10
Top right dash warning cluster £10
Hazard light switch £3
Folding mirror switch SOLD
Drivers door window and lock switches £15
Passenger door window switch SOLD
Face lift front and rear side running lights £10
Lights and wiper stalk switches £50
Silicone reducer 65 – 50mm £10
Silicone 80mm straight length 0.5m £30
Alpine CD changer wire £10
Ali turbo pipe work £40
Spoiler (in white) £50
O2 sensor SOLD
4 Spoke steering wheel £
Front brake discs (jap spec)(almost new)£70
Alternator (manual 100amp) £60
Power steering pump SOLD
Various rubber and plastic pipe work £offers
EDITED TO ADD - all prices plus postage.
Guest dee_rz
would you take £15 for the o2 sensor if it's in perfect order :) pm me with details to send payment and i'll send payment straight away
Bit of a long shot.
Face lift driver's door panel ? My one has come away from the internal handle.
Driver's door rubber ? Again, my one has worn down a bit.
Internal boot coverings / caps, that go around the boot, over the suspension tops. Those black plastic covers etc.
Facelift engine / spark plug cover, the one that is green ish, with toyota written over it.
Based in Worthing.
SBK
Ill deal with these when I get home from work via PM, but for now -
Simon K, sorry all the trim parts have gone, try giving Koptie a shout. I may have a door rubber but wont know until the weekend.
Cntt - yes I still have the aircon ECU, you do mean the white box that sits above the radio with the orange scockets?
yea thats right, the white box above the radio
I'm living in ireland so how much will it cost for shipping.
need that 50A fuse for the air conditioning(the one goes in the fuse box in the engine bay) aswell if you have one.
I wait for your pm.
can I actually add those facelift lights on the rear?
Yeah you can because i just have, Better get a body shop to cut the holes out, Dont want to mess it up as itll cost a bomb to fix... (Unless your good with stuff like that) Once the holes were done i made a loom up myself and wired them in.. Sorted
Ps JohnK: Do you still have the slip switch? If so how much in total with P&P
  • 4 months later...
