hid kit advice needed
Guest timalbert
hya,just to confirm then for my j spec i need to get 9005 hb3 bulbs.what do you mean when you say dipped and main beam? i take it main beam is for at night?
No dip beam is the central light of the 3, high beams are the inner most lights.
You need to use 9005/HB3 for the dipped beam and high beam on the J-spec lights. Correct bulbs are dipped 9006J and high 9005J, but these are not generally available, so you need to substitute both with 9005 bulbs (9006 will not fit).
This is only applicable with the J-spec lights, the UK glass headlights use 9006 low and 9005 high.
