Uprated auto boxes, any interest?
Chris Wilson
I was having a meal with my auto box guru pal and we discussed Supra Aisin Warner auto boxes. As a result it may be possible for me to offer a service whereby good auto boxes can be upgraded with heavy duty clutch friction plates and steel plates, and a re engineered valve body to give greater line pressure for less slippage giving higher torque handling capacities. I could off modded torque convertors, too, on an exchange basis, but would probably just farm this out to a rebuilder either here or in the US. Gearbox mods would be done in house though.
Any interest? Worth me getting soem pricings?
These boxes would NOT carry a normal warrenty as they are, by nature, being used way over their design limits, and the basic unit being upgraded would not be new, either.
Both UK and J-Spec boxes should be OK for upgrading.
I'll try and price the parts up next week. My pal is gettng part numbers for me over the weekend. If anyone has a duff auto box valve body I could start an exchange scheme for those and have them modded and ultrasonically cleaned, on the shelf. Then it would be just a valve body swap and change the clutch packs.
Obviously I'd pay for a valve body or a duff gearbox.
I have a wee bit of a slippage problem, when using kickdown from about 2-3k and it shoots into the high rpms, often i get what i imaging as the clutch slippping (of equiv). I have done all the fluid changes etc but still got the problem. would be very interested if it would sort that.
Guest Terry S
I thought the 2nd gear sprag was the weak link?
it is Terry which is why there are lock up issues at WOT on stock boxes when using higher stall converters in 2nd gear , the clutches are apparently not the weak point of this gearbox as some builders use stock Toyota parts , its the same old story if you want an Auto built go to the states , not only have they turned this into an art form but the builders can show you their transmissions working in 11,10 and 9 second cars , to my knowledge a supra has only once scraped into the tens in the uk , its only when you have quite a few passes on a trans that its integrity will be known ands theres more to it than chucking a few parts in and saying this is a 9 second box , perhaps one of the single lads would give one a go to see if it can hold up to some proper usage , personally i'll stick with the one im having built at the moment as i dont want to screw up a £1000 converter AND a box !!!;)
Dude:flame Dev
"Boost Logic MKIV TT Auto Upgraded Transmission
This transmission was tested and developed on BoostLogic’s 9 sec@142mph daily driven street Supra. This transmission has been tested for over 25,000 miles and counting, as the Supra it was tested on is a daily driver. More than 40 low 10 second passes have been made on this transmission and it still drives like the day it was put in. It shifts FIRMLY and INSTANTLY. It doesn’t shift too hard to daily drive but will HOLD the power at the track. Many cars have been using this transmission and are loving it. The price of this transmission does not do justice to the level of performance this transmission puts out. The transmission is half the price compared to other competitors and is PROVEN to run 9's in the 1/4 mile"
If anyone is interested I will get costs for the Boostlogic autobox?
__________________
Regards
Terry
Purple MKIV
BPU
if you hadnt guessed this is the daddy of transmissions , have a look on supraforums and see the opinions , and its CHEAP:D
Dude:flame Dev
