mikeyb10supra Posted July 20, 2006 Share Posted July 20, 2006 Is it safe to support the front of the car under the front wishbones where they join onto the suspension.....ie so at the bottom of the shock where it joins the wishbones? Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 20, 2006 Share Posted July 20, 2006 Like this? Under the wishbone to subframe bolt? Yes. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted July 20, 2006 Author Share Posted July 20, 2006 Hmm got mine under the bit were the suspension joins the wishbone, just behind where the wheel bolts on.....I take it this is still safe as its under the suspension? Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted July 20, 2006 Share Posted July 20, 2006 I put mine on the jacking points last time - is that a bad thing? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 20, 2006 Share Posted July 20, 2006 I put mine on the jacking points last time - is that a bad thing? With Wood I hope! Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted July 20, 2006 Share Posted July 20, 2006 With Wood I hope! Ok that doesn't help but I assume its a bad thing then, why's that if that’s the suggested jacking point? Quote Link to comment Share on other sites More sharing options...
albundy68 Posted July 20, 2006 Share Posted July 20, 2006 With Wood I hope! surely the underside of his supe cant look that good! Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 20, 2006 Share Posted July 20, 2006 Mikey, you want to support the car at the chassis end of the wishbone, not the wheel end. Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted July 20, 2006 Share Posted July 20, 2006 surely the underside of his supe cant look that good! Well it looks the same as before I jacked it up - thanks for your useful comment Quote Link to comment Share on other sites More sharing options...
TLicense Posted July 20, 2006 Share Posted July 20, 2006 Why not just use the published support points. You can find them here:- http://www.mkiv.com/manual/manualtt/vehicle_lift_and_support_locations/index.html Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted July 20, 2006 Share Posted July 20, 2006 Why not just use the published support points. You can find them here:- http://www.mkiv.com/manual/manualtt/vehicle_lift_and_support_locations/index.html thats what i used but it appears to be wrong, no one will actually say why though? Quote Link to comment Share on other sites More sharing options...
Sharpie Posted July 20, 2006 Share Posted July 20, 2006 thats what i used but it appears to be wrong, no one will actually say why though? OK, I'll take a stab at why Martin said "with wood" since we are in Chat What shape is the top part of your axel stand ? Flat or U (ish) shaped ? The stock lifting points are flat (ish) so, a U shaped top of an axel stand is going to do some damage - NO ? (well, that was how I read it) Quote Link to comment Share on other sites More sharing options...
grahamc Posted July 20, 2006 Share Posted July 20, 2006 thats what I would have thought, wood would protect the under side of the car. Quote Link to comment Share on other sites More sharing options...
Wez Posted July 20, 2006 Share Posted July 20, 2006 Why are the published toyota ones wrong, i have not used them myself for axle stands but see no reason why not. I normally just use a bit of common sense and place them somewhere solid, also depends how high i wanna get it and where i need access too. Quote Link to comment Share on other sites More sharing options...
