Sandy-m2 Posted July 19, 2006 Share Posted July 19, 2006 Ok guys got my MOT coming up and wanted some help. Things to check..... Tyre tred - 1.6mm+??? Disks and pads - how do I know if they will pass or fail? Lights - ??? Number plates - is it a reqirement to have a front one?? Exhaust - its standard so should be fine. anything else i should look out for. Thanks for any help in advance. S Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted July 19, 2006 Share Posted July 19, 2006 Lights - All lights, even the ones I always forget. Number Plate, fog. I think it is a requirement to have a front plate.. (Not 100% sure for MOT though) Disk/Pads - Are the pads very low. The only check is when they put it on the rollers (Unless they are cracked or something). Washer jets - Please don't run out of water as people have been known to do. Errr.... Quote Link to comment Share on other sites More sharing options...
absz Posted July 19, 2006 Share Posted July 19, 2006 lights-horn-washers-wipers-seatbelts-brake pedal travel-handbrake travel-fuel leaks-braking system-suspension-steering-front screen-mirriors-corrosion-hazards-sharp edges-and emissions:d hope that helps (i'm sure i've missed a few) Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted July 19, 2006 Share Posted July 19, 2006 yes, a front number plate is a requirement. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 19, 2006 Share Posted July 19, 2006 also check the bushes by shaking the steering wheel lightly left and right at an even pace. foglight must be red (in my case it was wired to the reverse light, so just wet a peice of red filter paper and slap it over it - done) all indicators, hazards, front fogs brake lines emmissions is the main one but all computerised and if youve got both cats in youll be fine mine passed with a VERY low emmission rating. they also check the fuel thing, open it up and remove the cap, check inside and close it again. Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted July 19, 2006 Author Share Posted July 19, 2006 Fantastic chaps you are all stars Quote Link to comment Share on other sites More sharing options...
Heyrick Posted July 20, 2006 Share Posted July 20, 2006 Mine's just been for MOT - first one since purchase so I was a bit concerned. Failed on the Hazard switch not staying on! Was working last week! Got it home and took it apart and the casing was slightly broken - bit (lot) of super glue = sorted. (But I don't think I'll be taking it apart again, lol! Quote Link to comment Share on other sites More sharing options...
