Paul R Posted February 12, 2004 Share Posted February 12, 2004 Hi, I have yet another problem now Coming back from wolverhampton this morning I started to get grinding noises when I put the brakes on. It only seems to happen if I hold my foot on the pedal for a long time or I brake hard. It's ok then I start getting a 'grrrrrrrrrrrrrr'... I've checked the pads and they all have at least 3-4mm on them still. Is this too low? Paul. Quote Link to comment Share on other sites More sharing options...
Paul R Posted February 12, 2004 Author Share Posted February 12, 2004 Can no one help me on this??? Paul. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted February 12, 2004 Share Posted February 12, 2004 Feck m8 - you get more noises out of that car then the Royal Philharmonic! Sounds enough pads - you may have picked up a stone between pads and discs? Does it come from any one brake? Quote Link to comment Share on other sites More sharing options...
Paul R Posted February 12, 2004 Author Share Posted February 12, 2004 Originally posted by Paul E Feck m8 - you get more noises out of that car then the Royal Philharmonic! Sounds enough pads - you may have picked up a stone between pads and discs? Does it come from any one brake? Some of the noises are good ones though!! It seems to be the front drivers side wheel. Paul. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted February 12, 2004 Share Posted February 12, 2004 Check for a stone lodged behind the discs Jack up the front and rotate the wheel Quote Link to comment Share on other sites More sharing options...
