Ewen Posted July 19, 2006 Share Posted July 19, 2006 (TT VVTI) Checked pipework in way of the air inlet and MAF sensor this morning, and I've got oil in the turbo outlet pipe. Not a lot, but its coating the inside of the pipe. Is this normal or not ? Link to comment Share on other sites More sharing options...
supRo Posted July 19, 2006 Share Posted July 19, 2006 That's normal mate. A little oil is fine. Link to comment Share on other sites More sharing options...
Ewen Posted July 19, 2006 Author Share Posted July 19, 2006 That's normal mate. A little oil is fine. Thanks. Link to comment Share on other sites More sharing options...
supRo Posted July 19, 2006 Share Posted July 19, 2006 Thanks. Actually as it is a newer VVTI car, probably best if someone more technical answers the question! Link to comment Share on other sites More sharing options...
Ewen Posted July 19, 2006 Author Share Posted July 19, 2006 Actually as it is a newer VVTI car, probably best if someone more technical answers the question! I'd just stepped back from the edge... Link to comment Share on other sites More sharing options...
Alex Posted July 19, 2006 Share Posted July 19, 2006 It's ok - it's oil from the PCV on the side of the cam cover. Link to comment Share on other sites More sharing options...
supRo Posted July 19, 2006 Share Posted July 19, 2006 It's ok - it's oil from the PCV on the side of the cam cover. There you go Ewen Link to comment Share on other sites More sharing options...
Alex Posted July 19, 2006 Share Posted July 19, 2006 Just to add if it start chucking bucket loads of oil in there you do have a problem...but a light amount is perfectly normal. Link to comment Share on other sites More sharing options...
Ewen Posted July 19, 2006 Author Share Posted July 19, 2006 There you go Ewen its just a film of oil, but I'll keep a regular eye on it. Link to comment Share on other sites More sharing options...
