dude Posted February 11, 2004 Share Posted February 11, 2004 Going to fit it soon . Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 Quote Link to comment Share on other sites More sharing options...
Nick_TC Posted February 11, 2004 Share Posted February 11, 2004 Nice, but you want to buy your welder some new glasses Quote Link to comment Share on other sites More sharing options...
matt Posted February 11, 2004 Share Posted February 11, 2004 Won't the hose come off under boost? Needs a lip on it ? Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 Originally posted by matt Won't the hose come off under boost? Needs a lip on it ? Not with the clamps that i use !!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 Originally posted by NWS25 Nice, but you want to buy your welder some new glasses Can you do that reall really neat tig welding type stuff , id just love to be able to do that !!!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Nick_TC Posted February 11, 2004 Share Posted February 11, 2004 If you done it mate then it aint to bad for a monkey You give me a discount on a re-spray and I'll teach you how to weld. Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 Originally posted by NWS25 If you done it mate then it aint to bad for a monkey You give me a discount on a re-spray and I'll teach you how to weld. Thanks dude , it looks better in the flesh !!! .... slinks off to the welding for dummies class !!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Nick_TC Posted February 11, 2004 Share Posted February 11, 2004 Not the best of pics, and cant find one of when it was polished either http://homepage.ntlworld.com/bsau23/project350/IC/capt008.jpg Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted February 11, 2004 Share Posted February 11, 2004 John, looks totally crap ..... Naa, its not that bad! Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 No matter wont be long and youll only be able to see it for 10 seconds at a time !!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 11, 2004 Share Posted February 11, 2004 Why just the end dude ? I assume it's to get more air in but, the section that bolts to the intake manifold is the same dia right ? would you not have to have a wider TB and also a modded/replacement Intake manifold too, to get the most out of it ? just wondering. Quote Link to comment Share on other sites More sharing options...
dude Posted February 11, 2004 Author Share Posted February 11, 2004 Originally posted by Peter Sharp Why just the end dude ? I assume it's to get more air in but, the section that bolts to the intake manifold is the same dia right ? would you not have to have a wider TB and also a modded/replacement Intake manifold too, to get the most out of it ? just wondering. A big F**k off manifold would be lovely but this is just to get rid of the TRAC butterfly (ive had it disconnected for a while now ) Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 11, 2004 Share Posted February 11, 2004 Do J-spec's not have this extra bit then on the TB ? Don't know what it is though. Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted February 11, 2004 Share Posted February 11, 2004 No matter wont be long and youll only be able to see it for 10 seconds at a time !!!! Well see! ............. Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted February 12, 2004 Share Posted February 12, 2004 John, not being picky but by you using a larger pipe into the throttle body, yet retaining the same diameter after the throttle flap you will ahve a good sized lip around the incoming air, thus causing turbulance and kind of decreacing air pressure? Am I missing something? Rgds U Quote Link to comment Share on other sites More sharing options...
dude Posted February 12, 2004 Author Share Posted February 12, 2004 OD of both pipes is the same , the step is not very noticable in real life but sometimes turbulence is a good thing , the headers on a lot of yank drag racers have a small bead of weld around the inside of the top of the tube , this creates a vortex that sucks out the exhust gas as well as it being pushed out , this was tested on the dyno and proved very effective. Dude :flame Dev Quote Link to comment Share on other sites More sharing options...
dude Posted February 12, 2004 Author Share Posted February 12, 2004 Originally posted by Usmann A Well see! ............. Only for about 10 seconds though!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted February 13, 2004 Share Posted February 13, 2004 Proper TRAC removal! Quote Link to comment Share on other sites More sharing options...
skylinelee Posted February 13, 2004 Share Posted February 13, 2004 nice shiny bit dude if your clamp comes loose use no nails, monkey used it on his new trd rear spoiler instead of bolts, to save weight:D not fallen off yet, he had a few runs down the rear where he used to much glue, but got that off easily with paint stripper. lee Quote Link to comment Share on other sites More sharing options...
