Alex Posted July 19, 2006 Share Posted July 19, 2006 Nice overlay Nic. FWIW people who just do the ETTC mod WILL NOT get Nic's results. Nic's car is mapped on an eManage and the timing has been adjusted to make the best of his permanently modded setup. Have to say I'm impressed by Nic's results as I didn't think TTC could be that good. Hats off to the mapper. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 19, 2006 Share Posted July 19, 2006 I thought I would overlay my dyno graph (I only have hp), I am running BPU on stock jap turbos at 1.25bar, but in TTC (parallel). See my garage for full spec It is interesting to see how the power curve compares to Homer's BPU Supra running in sequential mode, we are both making similar top end power, but I seem to gain a lot of mid range power running in parallel. [qimg]http://img147.imageshack.us/img147/8074/t61vsbpubm7.jpg[/qimg] edit just seen your garage Nic. Was the car dyno'd in 5th? Your car makes less torque than Homers, or is that my reading of the graphs? Quote Link to comment Share on other sites More sharing options...
Nic Posted July 19, 2006 Share Posted July 19, 2006 Agree with you Alex, I would not advocate switching to TTC without having some way of remapping the fueling and ignition. I was actually very suprised to see just how much extra mid range power I get compared to a BPU car with sequential setup. I was also suprised that I don't actually loose much power at lower rpms. Mine is converted to TTC permanently by switching the vacuum hoses around, rather than the electrical conversion. I also have HKS cams fitted (i256/e264) and have had some mild head work done, which I guess helps gain some extra mid to top end power. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 19, 2006 Share Posted July 19, 2006 edit just seen your garage Nic. Was the car dyno'd in 5th? Your car makes less torque than Homers, or is that my reading of the graphs? It was a dyno dynamics dyno, not sure what gear it was done in (doesn't say on the graph I have). I don't have a torque graph here, the line I added is the hp only, I'll get a torque graph and add that too. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 19, 2006 Share Posted July 19, 2006 It was a dyno dynamics dyno, not sure what gear it was done in (doesn't say on the graph I have). I don't have a torque graph here, the line I added is the hp only, I'll get a torque graph and add that too. OK, just most people will dyno in 5th, which adds load so it will spool faster. Both the others were in 4th. Also in my experience the HKS Cam combination moved the whole power curve to the right a bit. The Flowed head may well be helping yours as well. Quote Link to comment Share on other sites More sharing options...
Clarkey Posted July 19, 2006 Share Posted July 19, 2006 With Farnborough airshow the roads out of my street are closed. If I can find an alternative route out ... I'll see if I can pop to Surrey Rolling Road ... be interesting to see the comparison between mine .. Terry's & Darryl's. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 19, 2006 Share Posted July 19, 2006 Just to add my graph (and Homers judging by the figures) is estimated flywheel power (generated by the dyno) NOT rear wheel hp. Is yours rear wheel power shown Terry? Not a good comparison with yours if it is. I was more interested in the comparison with Homers as his has similar power and some similar mods to mine according to his garage. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 19, 2006 Share Posted July 19, 2006 No Nic it's FW ( the turbo simple couldn't flow enough for it to be at the wheels), but RWHP could be applied for other dynos here in the UK If you are going near the dyno anytime soon, ask them to do it in 4th then we will be able to compare properly mate. Quote Link to comment Share on other sites More sharing options...
Clarkey Posted July 19, 2006 Share Posted July 19, 2006 If you are going near the dyno anytime soon, ask them to do it in 4th then we will be able to compare properly mate. Will do! Just got off the phone to them .. and the next available slot they have is anytime in the 1st week of August. Got to ring the guy again tomorrow to booking ... as said he was the train-station. Must've re-directed the call to his mobile. Quote Link to comment Share on other sites More sharing options...
Clarkey Posted July 19, 2006 Share Posted July 19, 2006 What fuel were you guys using ? Optimax or Tesco 99 ? As I'll use the same. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 19, 2006 Share Posted July 19, 2006 Optimax Christian, can't say for darryl. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 19, 2006 Share Posted July 19, 2006 If you are going near the dyno anytime soon, ask them to do it in 4th then we will be able to compare properly mate. I've just spoken to the tuners, they said they do the power runs on manuals in 4th usually. He didn't have the info for mine at hand, but said it was most likely done in 4th gear. I'll get a torque graph when I'm next there and add this to the graph. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 19, 2006 Share Posted July 19, 2006 I've just spoken to the tuners, they said they do the power runs on manuals in 4th usually. He didn't have the info for mine at hand, but said it was most likely done in 4th gear. I'll get a torque graph when I'm next there and add this to the graph. Quote Link to comment Share on other sites More sharing options...
supRo Posted July 19, 2006 Share Posted July 19, 2006 Let me know when you go to the Dyno as I live in Farnborough which is next to Camberley (Surrey Rolling Road). Mines a BPU, assuming my car is fixed by then, I'll get mines Dyno'd Ro Quote Link to comment Share on other sites More sharing options...
