PHR stage 2 vs BL T67 stage 2
wkdtime
BL T67 Stage 2 or PHR Stage 2?
36 members have voted
  1. 1. BL T67 Stage 2 or PHR Stage 2?
    • BL T67
      18
    • PHR
      18
This is a discussion regarding the non DBB as the extra cost is out of my budget, plus mines a 6 speed.
So here are the questions, assuming both will have the same fueling as theyre pretty much similar sized units.
Build quality?
Low down boost?
Power attainable with supporting Mods.?
pros and cons?
Which one would you have?
Edit, Just been reading on the US forum, PHR and BL are both well rated, but the general consensous on the forum is the the PHR kits are over priced and have a weaker manifold than the BL Kit.
  • Replies 70
Yes the PHR kit use a GEnuine HKS manifold. We have supplied 4 PHR kits and the quality is outstanding.
We have also supplied the BL kit.
If you are looking for a difference, you just simply wotn feel on on the road. They are both VERY VERY good kits and do pretty much the same job.
My advice - If you want the very best and your a lable Biach - PHR. If you want the same kit, but dotn mind a kock off manifold - BL.
Back to the drawing board for me:(
Why? If I understand correctly, you don't want DBB, right? So you don't need water lines anyway.
You just need to choose between PHR and BL. I'd be happy with either. I would have chosen BL but I ended up buying a car that already had a PHR stage one kit fitted and it seems like good stuff. I really like the way the IC hard pipe doesn't go through the wing.
Can't go wrong with either PHR or BL I reckon.
Thanks Jake, i think ill get some estiamates when the time comes for each installation DBB and non DBB, i think ill be going for the BL,
The BL kit somes with a 50mm wastegate, but the PHR with a 65mm wastegate, could i use a 65mm wastegate with the BL kit?
50mm is ample, there is no need to go larger for a 67mm turbo
I would be going for the Stage 2 set up if i went BL, Martin the bigger the wastegate the more boost that can be controlled?
The PHR is around them same size as the BL, then why does that have a bigger wastegate, sorry about the million and one questions Lee and Martin, just wanna get my head round all this.
Yes but as Lee said you cant safley make enough boost on stage 2 to overwhelm the 50mm.
I think i heard terry say that the dbb is good on manuals but makes no difference on auto's.... i might be wrong but im sure terry will be along soon:)
I thought the whole point about the DBB was being able to spool faster, so it would make more of a difference on an auto I'd have thought. :conf:
(Edit - more difference to drivability.)
TBH the differences probably arnt worth arguing about :)
