grimreaper Posted July 15, 2006 Share Posted July 15, 2006 can you fit turbo rear discs to a non turbo? Link to comment Share on other sites More sharing options...
Nic Posted July 15, 2006 Share Posted July 15, 2006 Yes the larger 4 pot front and 2 pot rear brakes will fit an NA provided your wheels will clear the calipers (they won't fit under the stock 16" wheels). BTW. The larger brakes were an option on the NA and TT Supra so calling them turbo brakes is a bit confusing ps. give me a shout if you want prices for the bigger brakes. Link to comment Share on other sites More sharing options...
Kopite Posted July 15, 2006 Share Posted July 15, 2006 But i'd put the fronts on too to help keep the braking bias Link to comment Share on other sites More sharing options...
Jake Posted July 15, 2006 Share Posted July 15, 2006 i'd put the fronts on too to help keep the braking bias DO NOT FIT UK SPEC REAR BRAKES UNLESS YOU HAVE UK SPEC FRONT BRAKES Unless you are felling suicidal. Link to comment Share on other sites More sharing options...
grimreaper Posted July 15, 2006 Author Share Posted July 15, 2006 are toyota discs ok or is there a better make of discs, my mk3 supra discs i got from toyota years ago warped after 20,000 miles so i dont want to pay out for toyota discs on my mk4 if they are not anygood? Link to comment Share on other sites More sharing options...
dangerous brain Posted July 15, 2006 Share Posted July 15, 2006 One thing also to consider is if these brakes will fit on with your wheels. If you have stock 16's forget it they won't fit. Link to comment Share on other sites More sharing options...
MARTIN R Posted July 15, 2006 Share Posted July 15, 2006 Yes the larger 4 pot front and 2 pot rear brakes will fit an NA provided your wheels will clear the calipers (they won't fit under the stock 16" wheels). BTW. The larger brakes were an option on the NA and TT Supra so calling them turbo brakes is a bit confusing ps. give me a shout if you want prices for the bigger brakes. I have UK front brake set up. how much for a rear upgrade? Link to comment Share on other sites More sharing options...
