hob Posted July 12, 2006 Share Posted July 12, 2006 Is this required to get the mirror reflection? I have some other stuff such as brasco? metal polish, would this be ok? the mian problem is I cant use my car because all the bits are out ready to be polished but I realised I have no grit is there anything as good? if not where would sell this grit, halfords B&Q etc? Link to comment Share on other sites More sharing options...
Jake Posted July 12, 2006 Share Posted July 12, 2006 Might help if we knew what "bits" are you talking about. Link to comment Share on other sites More sharing options...
peter richards Posted July 12, 2006 Share Posted July 12, 2006 hope its not the bodywork Link to comment Share on other sites More sharing options...
hob Posted July 12, 2006 Author Share Posted July 12, 2006 Might help if we knew what "bits" are you talking about. sorry engine bits, such as alternator inlet manifold etc Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 13, 2006 Share Posted July 13, 2006 grit? never heard of it. if you're polishing inlet manifold ect then its buffing wheel and wax time (i assume they stock, never touched) Link to comment Share on other sites More sharing options...
Jake Posted July 13, 2006 Share Posted July 13, 2006 Non-intricate areas (not the altenator) can be done with polishing/buffing mops and polishing wax on a pillar drill or bench grinder. A sander and even a angle grinder can be usefull to remove really rough casting marks before finally polishing. It needs to be done in stages. Long and tedious work it is. I've spent many hours polishing stock turbo pipework etc but good results can be achieved. Link to comment Share on other sites More sharing options...
hob Posted July 13, 2006 Author Share Posted July 13, 2006 grit? never heard of it. if you're polishing inlet manifold ect then its buffing wheel and wax time (i assume they stock, never touched) Hmm wax? what sort of wax? (some of the wax contains grit) http://www.thepolishingshop.co.uk/ they recommend "Satine Abrasive Compound 330g" grit 80-400 Ideas of where to buy the wax rather than online Link to comment Share on other sites More sharing options...
Jake Posted July 13, 2006 Share Posted July 13, 2006 MachineMart Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 13, 2006 Share Posted July 13, 2006 that's where i got mine Link to comment Share on other sites More sharing options...
hob Posted July 13, 2006 Author Share Posted July 13, 2006 wohoo tah peeps ordered some Link to comment Share on other sites More sharing options...
Jspec Germany Posted July 13, 2006 Share Posted July 13, 2006 Mother's Metal polish Link to comment Share on other sites More sharing options...
